  1. #1 Regal Raptor in CIMAmotor
    C-Moto Regular xacarrere's Avatar
    Jul 2009
    Valencia, Eastern Spain
    Was held in Chongqing, the 8th international exhibition of Chinese motorcycle CIMAmotor, regal raptor was present.
    In this link are the novelties of regal raptor, http://www.cimamotor.com/chs/onlines...20/index.shtml
    The novelty is the new version of the model SPT 400 cc
    Greetings riders
    Regal Raptor Riders passion regal raptor
  2. #2 Re: Regal Raptor in CIMAmotor
    Apr 2008
    NoVA
    Looks a little like...
    Only with water cooling and alloy wheels?
  3. #3 Re: Regal Raptor in CIMAmotor
    Jul 2009
    Motorcycle data SPT regal raptor 350 cc
    the same technical characteristics cimamotor motorcycle, but with smaller engine capacity and different aspect
    is the same, but different versions
    Length×width×height mm 2125×840×1115
    Wheelbase mm 1470
    Fuel Tank capacity L 28±0.5
    Kerb weight kg 160
    Rated load kg 165
    Max. speed km/h 145
    Brake type(Front / Rear) Disc / Disc
    Brake Operating(Front / Rear) Manual / Foot Brake
    Wheel Rim(Front / Rear) Light alloy / Light alloy
    Tyre size(Front / Rear) 100/90-18、130/80-17
    Tyre pressure(Front / Rear) kPa 225/225
    Engine Model No. DD262MP
    Make Regal-Raptor
    Identification / Type Double cylinder, 4 stroke, water-cooled
    Manufacturer LiFeng Group Co.,Ltd
    Bore × Stroke mm 62×53
    Engine capacity cc 320
    Compression Ratio 10.2 :1
    Max. Power kW/(r/min) 17kw/8500rpm
    Max. Torque N·m/(r/min) 22N.m/6500rpm
    Mini. Idle Speed r/min 1500±100
    Mini. Fuel Consumption g/(kW·h) 354
    Fuel Type RQ-93
    Lubrication Forced lubrication
    Lubricant Type SAE 10W/40 API SG
    Clutch Type Oil-bathing multi-plate clutch
    Starting Electric start
    Ignition ECU+CDI
    Horn Type DC(direct current)
    Injection Type EFI (or Carburetor)
    Spark Plug CR7HSA
    Radio Interference Suppression Screened + Impedance
    Pollution Control Description Catalytic converter +EFI(or not)
    Speedometer Type Magnetic inductive
    Headlight Type One light, Sealed headlight
    Rearview Mirror Type Rectangular
    Transmission Ratio
    Primary: 3.631 Terminal: 2.286 Successive transmission ratio:/
    I^:2.846 Ⅱ^:1.777 Ⅲ^:1.333 Ⅳ^:1.083 Ⅴ^:0.913 Ⅵ^:/
    I do not see the resemblance to Qingqi
    this bike looks bigger
  4. #4 Re: Regal Raptor in CIMAmotor
    Apr 2008
    NoVA
    Well yes it is a bigger bike being a 350-400, but the styling is similar. All black, two 17" wheels. Large capacity tank with standard foot peg positions. Under seat exhaust, "sporty" one piece saddle. The original picture of the red motorcycle you posted the first time also has the high mounted front fender.
  5. #5 Re: Regal Raptor in CIMAmotor
    Jul 2009
  6. #6 Re: Regal Raptor in CIMAmotor
    C-Moto Guru david3921's Avatar
    Jan 2009
    Wyoming, Michigan USA
    Quote Originally Posted by CrazyCarl View Post
    And a lower fender as well. It looks like they were trying to make a sumo type by adding the mx fender but forgot to remove the stock one.
  7. #7 Re: Regal Raptor in CIMAmotor
    Senior C-Moto Guru ZMC888's Avatar
    Oct 2008
    Zibo, Shandong - Sometimes SW England
    Sorry Carl I've ridden both and they are extremely 'unsimilar'! If you had a photo of both together, it would be quite obvious, the camera makes a certain similarity, due to lack of dimensional 3D perspective.
    Without consciousness, space and time are nothing; in reality you can take any time -- whether past or future -− as your new frame of reference. Death is a reboot that leads to all potentialities.
  1. Regal Raptor DG-350E-6
    By LH1953 in forum Street
    Last Post: 01-25-2020, 03:39 AM
  2. Regal Raptor Custom Gallery
    By xacarrere in forum Manufacturers and Importers
    Last Post: 08-28-2015, 12:07 PM
  3. Products regal raptor
    Last Post: 07-18-2011, 03:19 PM
  4. Regal Raptor DD250G-2 (2008-09)
    By ZMC888 in forum Street
    Last Post: 04-18-2011, 01:17 AM
  5. Regal Raptor 250E-9B
    By petedeuxwheels in forum Street
    Last Post: 03-18-2009, 12:04 PM
