#1 Tachometer indicates more revs than real! Qingqi supermotardRiding in Honduras C.A.
- Jun 2009
- Honduras
04-05-2010, 05:32 PM
Hi Folks
My Qingqi Supermotard 200cc has a tachometer that indicates more revs than real.
Itīs weird couse doesn't happen all the times. Sometimes its ok.
I Know this couse in 5th gear at 6500 rpm the speedometer show 100km/h but the other day was at 5th and 100km/h and the tachometer shows 10 000 rpm. I stop an at idle shows 3500 rpm
What can be wrong?
Anything else seems to work OK. I made a 1200km trip this week (semana santa) with no problem besides the tach.
Im sure this is not good. But can't figure it out.
Thanks in advance
andres357magQingqi 200 Supermotard. (Genesis) Mods Until now:Rised Handelbar with stock risers and a lot of washers. Almost 10cm. Pillion handles eliminated and enduro model rack puted in place with turn signals just ziptied to it. Abominable Top Box over rack! Kickstarter removed for comfort (now inside TopBox). PCV pipe bolted to subframe holding my tools. Acerbis supermoto handlebar protector. Turnsignals bolted to the Abominable Top Box base.
#2 Re: Tachometer indicates more revs than real! Qingqi supermotardC-Moto Noob
- Apr 2011
- Romania
04-10-2011, 11:08 AM
Hi there..
I think that is a problem with the cable that measures the rpm's... You can change that cable and see if there a change is made.
If you don't know where the cable is located, give me a feedback and i will show you a photo.
#3 Re: Tachometer indicates more revs than real! Qingqi supermotard
04-12-2011, 12:06 AM
Those tachs units are known to be fidgety. If you haven't been playing around with the wiring, then it's probably just the unit. I've seen that model tach on a couple other bikes so I'm not sure if it's an adjustable unit.
#4 Re: Tachometer indicates more revs than real! Qingqi supermotard
06-23-2011, 05:30 PM
would i be right in thinking that these units take their readings from the coil? if thats the case then if there are no running problems then yes it could just be a faulty tacho.
Qingqi supermotard Weird behaivour of turn signals
By andres357mag in forum MaintenanceReplies: 9Last Post: 08-24-2012, 07:48 AM -
Kinlon 200 Supermotard?
By decessus in forum Dirt n' Dual-SportReplies: 6Last Post: 04-21-2012, 11:16 PM -
Qingqi 200 supermotard turn off while handbars turned all to the right
By andres357mag in forum MaintenanceReplies: 6Last Post: 01-15-2010, 07:55 PM -
Hubei holiday for a real bike?
By ZMC888 in forum Ride Prep and Making TracksReplies: 7Last Post: 10-16-2009, 03:31 AM -
how to clear the " Carburetor" of QingQi SUperMotard ??? help !i'm New to this.
By GXT200_Costarica in forum MaintenanceReplies: 5Last Post: 07-20-2009, 09:25 AM
