Thread: Qlink XF200 Carb questions
#1 Qlink XF200 Carb questionsC-Moto Not-so-Noob
- Oct 2009
04-06-2010, 10:28 PM
I have a XF200 I purchased used (with 200km on it). The person who
originally bought it installed a FMF Turbine Core 2 exhaust on it. The
bike runs rich and bogs only at full throttle and fouls out the plugs
pretty quickly. I thought the previous owner might have put a bigger
main jet in but when I pulled out the main jet it was a 125 which I
believe is stock (or close to it). Shouldn't the bike be running lean with a bigger
exhaust under these circumstances? I added a 132.5 main jet and now it
cuts out at high throttle so appears that it's running even richer
now. I am going to put in a Moose air filter to increase airflow as my
next step and go back to the 125 main jet. Do you all have any other
ideas? One other issue I am having. When I removed the main jet there is a washer but I cannot get the jet back on with the washer on, the jet is not long enough. Thanks
#2 Re: Qlink XF200 Carb questions
04-07-2010, 01:00 AM
Nimbus, my Q came originally with a 122.5 jet, as I think most do. I changed it to a 125 when I changed the exhaust. Send a PM to forchetto and he should be able to help you with your issue. It's been awhile since we've heard from him any way.
Edit: there is a needle on these type of carbs also and the clip can be moved. Maybe the PO moved the clip to make it run richer.
#3 Re: Qlink XF200 Carb questionsC-Moto Not-so-Noob
- Oct 2009
#4 Re: Qlink XF200 Carb questions
04-08-2010, 01:33 AM
Is there enough thread to grab? A picture would help since it can be compaired to others on this site.
Pics Of My Qlink XF200
By firefightermatt in forum Dirt n' Dual-SportReplies: 17Last Post: 12-04-2010, 05:52 PM -
Qlink XF200 gas mileage
By david3921 in forum StreetReplies: 2Last Post: 06-05-2009, 02:44 PM -
Qlink XF200 light; not sure why it's there...
By david3921 in forum Dirt n' Dual-SportReplies: 2Last Post: 03-07-2009, 06:28 AM -
anyone tried pro circuit t-4 for qlink xf200?
By bergspre in forum Modifications (Cosmetic and Performance)Replies: 4Last Post: 12-31-2008, 05:41 PM
