Thread: AGB-30F Cross 250cc
Results 11 to 18 of 18
#11 Re: AGB-30F Cross 250ccC-Moto Not-so-Noob
- Apr 2010
04-29-2010, 08:05 PM
Anyone know where one can download a PDF for Orion bikes? As I have no manual or service book.
I assume several other models listed here on this site under dirt bikes are from the same manufacture at least the 250cc engines. AGB-30/ orion/ Galaxy
#12 Re: AGB-30F Cross 250ccC-Moto Not-so-Noob
- Apr 2010
05-12-2010, 03:46 AM
Ok I've come up to 400km with 50% hard off road riding. Front brake bolts backed out leaving the whole assembly dingling in the wind at 60mph... front radiator bolts loose, chain adjustment backed out, and engine idle screw keeps backing out. I suspect this minor stuff for the most part, and a little loctight on the threads seems to fix most of the loose stuff. The ride is still a little hard, so need to find alturnative, as the rear shock is at the lowest position. front end seems ok, but easy to wash out in sand or gravel, feels like you sit to high with body weight to far forward, I believe the mechine would be more forgiving if the rear end was dropped 3 in. at least in sand or loose material. I'll post again at 800km
#13 Re: AGB-30F Cross 250ccC-Moto Noob
- May 2010
- Sweden
05-14-2010, 05:59 AM
Hej från Örnsköldsvik TC,
I also have the same bike but branded as a Hummer 250 (http://www.swebike.se/index.php?cPath=39_467_480). I have found no service manual or information at all on the net and have been looking for the past year. I have my bike for 10 months now and it was 18 months old when i purchased for 6000kr (600 €). It had maybe 30 hours on it when i purchased it.
A few points worthy of note:
1. replace all brake bolts.. they sheer easily.
2. Tighten all bolts every 4-5 hours, including those for the plastic fairings etc... I replaced these bolts as well.
3. The throttle cable is bad.... replace it but go for a good qualoty one.
4. Double check the chain, mine broke after the first few hours, but that was as a result of a bad repair by the previous owner.
5. the side stand bracket is weak weak weak! mine has broken so I have removed it altogether...
6. The throttle doesn't snap back, the spring in the carb is too wak and needs to be replaced.
I have the opposite problem to you with the suspension. My rear is way to soft even after adjustment and the front is rock hard. I have no idea how to adjust the front shocks and I guess they are supposed to be gas filled ???
My engine also revs high at idle (no matter the choke setting), I have adjusted the cárb but there seems to be no middle ground, i.e. it eithr revs too high or stalls at idle.
However, in saying that it is enormous fun, very durable and really quite reliable. I have clocked up about 20+ hours of serious trail and quarry riding and have dropped the bike pretty much every time. I have only damaged the handlebars (will take a trip to Biltema in Sundsvall in a few weeks to get a new one).
The fuelling is a bit crap however, when hot and if I am riding up a very steep incline she will cut out sometimes. It feels like it gets fuel-starved but I am not mechanically minded enough to properly troubleshoot the problem.
My bike really needs a service but I m unsure of where to start as I do not have valve adjustment specs ans don't even know the correct quantity or type of oil to use. Amazingly enough I have not changed the oil since i bought it and it has lost almost nothing!
The engine itself never fails to start but needs ulkl choke for about a minute then half choke until warm. The exhaust is bloody loud!!! It is quite torquey and doesn't like being revved very high, but I find I rarely need to as even in low revs it has enough pulling power to get over most surfaces.
You can email me at moore.rory(at)gmail(dot)com for service ideas....
R:
#14 Re: AGB-30F Cross 250cc
05-14-2010, 03:36 PM
Red.King
Welcome to MCM. Reading your problems with the bike, have you checked for a vacuum leak at the carb boot? (where the carb rubber mounts to the engine). Also, how long between valve adjustments?
#15 Re: AGB-30F Cross 250ccC-Moto Noob
- May 2010
- Sweden
05-14-2010, 06:40 PM
Hi Carl,
I would reckon the valves have never been calibrated to be honest and now that you mention it, it would seem like the most likely cause. I do not know the clearances despite seeking info on the net. The carb sits neatly and has no fault as far as I can see other than the butterfly valve was a bit stiff when I got the bike. It was actually a build up of crud as the previous owner had the removed the filter (a sponge sock
) and also drilled holes in the ait filter housing.... presuming in an attempt to increase airflow and thus hp... Which reminds me.... must pick up a proper airfilter for it..
If anyone has the valve clearances for the Zongshen 250cc motor and also the oil quanity for a complete fill and change it would be much appreciated
. I am guesing that 1 liter should do it but will probably put in 750ml and run it hot and then top up if I feel it is needed.
Just back from a spin in a sand and rock quarry up the road from my house.... as basic as the bike is..... it really is a lot of bloody fun and a great way to learn to handle the rouh stuff..... It is my first dirt bike and would like to keep it in good shape
Another thing you guys may be able to help me with, on the rear swing arm (chain side), there is a rubber mount that sits on top of the arm. This 'strip' of rubber acts as a guide for the chain on the return back to the drive sprocket so that the chain doesn't rub off the arm....... Erm... what is it called and where can I get a replacement?? I have asked the Swedish dealer for the bike but he hasn't a clue what i am on about...
Is there a technical name for this item or will 'super-duper-rubber-mounty-thingy-for the chain-rear-swing arm-protector' do...
R:
#16 Re: AGB-30F Cross 250cc
05-14-2010, 10:35 PM
Yes, you should at least try to keep it in a good shape. Respect your bike. Your life is in it. Treat it with that in mind.
I have to say that the biggest thumbs down biker video I have ever seen was were some "heroes" drived China Bikes in Middle East or somewhere. They came to a river stream and some failed to pass it. One however managed to pass the river and instantly after getting to the other side dropped the bike down rudely and begun to celebrate wildly. I know many think they are the most excellent and easily forget it was still the bike who carried them, but.... but what, I would never ride a meter with them. Call me arrogant but there are some things what I don't accept. That was about as disgusting video as was one ride report from some other "heroes" in Thailand who bragged like there would be no tomorrow with how they drove like there would be no other people on the public roads. And like that would be not enough, they made derogatory comments and pictures of the locals. I really wished I would had been there and been also brave enough to duel them one by one, even though violence is not a solution. But it would had been only a driving lesson and some basic teachings about respect.
#17 Re: AGB-30F Cross 250cc
05-14-2010, 11:13 PM
My bike is a different make, a Kinlon, but has the same kind of part, a small guide with a plastic rubbing strip - in the parts manual it is called a ....'chain guard' believe it or not!!! lol
Your dealer can go direct through here (in english) http://www.apollovehicle.com/Motorcy...B_30D_316.html
or he can live chat with the scandinavian rep ... http://settings.messenger.live.com/C...ive.com&mkt=en ... maybe you could pretend you are him as they talk to dealers only, but say you are translating for him!!!!
You may find parts or a manual on this site if you know the other brand names for your machine: http://www.chinesemotorcyclepartsonline.co.uk/ or through an Apollo Orion dealer, there are lots of them.
#18 Re: AGB-30F Cross 250ccC-Moto Noob
- May 2010
- Sweden
05-16-2010, 03:03 PM
Thanks Jape,
some good advise! Will do a bit more surfing tonight and see what I come up with. I also need to pay my forks some TLC as they are pretty rough. May just try to replace them with a scrapped Japanese model if I come across a set.
Was out again today, am getting bolder in the dirt and sand :) .... Funny as it may sound, but I have been riding road-bikes since my teens and feel that the dirt skills are paying dividends with my road riding. Here in Sweden we have a lot of gravel back roads and also gravel and sand left on the tarmac roads after winter.. My bike control feels better (more confidence I suppose ??).
Thansk again folks
R:
Two french guys on quads cross China?
By bigdamo in forum AsiaReplies: 0Last Post: 11-22-2009, 10:55 PM -
GS Rider Looking to Cross China...
By turbocharger in forum Welcome to MCM!Replies: 16Last Post: 01-15-2009, 03:39 PM -
China Cross Country Begins Tomorrow!
By Kurisu in forum Ride Prep and Making TracksReplies: 12Last Post: 11-06-2008, 09:44 AM -
Copy and paste cross-posting
By CrazyCarl in forum Test TrackReplies: 5Last Post: 06-01-2008, 04:21 PM -
Shineray GY-7 with 250cc engine
By Supersignet in forum Dirt n' Dual-SportReplies: 9Last Post: 05-03-2008, 02:41 AM
