#1 Removing Front Wheel - Pulse Adrenaline
- Jun 2011
- UK
06-03-2011, 09:39 AM
Hi All,
I was wondering if anyone knows the name of the tool I need to remove the front wheel from my pulse adrenaline as I am needing to replace the speed drive. Its not the normal nut & bolt type on the spindle, it looks like a big Hex Key or Torx. Its kinda like a Negative Nut. I have the Haynes manual, but it only has nuts & bolts on the pic in the book.
Any help greatly appreciated.
Mike
EDIT : I think it might be something like this I need, can anyone confirm? I think its 14mm according to my ruler
#2 Re: Removing Front Wheel - Pulse Adrenaline
06-04-2011, 11:51 AM
Yep, you need a 14mm allen head wrench. You'll need a smaller one to loosen the pinch bolt also. Do not over tighten the pinch bolt when re-installing, however. The bottom of the fork it cast aluminum and overtightening can crack it.
Check out this post as to what happened to McKonker when the dealer overtighted the pich bolt.
http://www.chinariders.net/modules.p...ghlight=konker
#3 Re: Removing Front Wheel - Pulse Adrenaline
06-04-2011, 01:40 PM
A 14mm headed bolt with a couple of nuts locked on it inserted in the axle shaft will work. I put one in my tool kit on the bike.
Vince
#4 Re: Removing Front Wheel - Pulse Adrenaline
- Jun 2011
- UK
06-06-2011, 11:03 AM
Thanks for your Reply's everyone.
new pulse adrenaline owner
By offtheclockuk in forum Welcome to MCM!Replies: 3Last Post: 05-25-2011, 06:57 AM -
Pulse Adrenaline
By Rodders in forum Dirt n' Dual-SportReplies: 24Last Post: 02-01-2011, 04:47 PM -
pulse 125 front sprocket
By sammy in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 10-28-2010, 01:50 AM -
Nearly Done; Pulse Adrenaline
By Sprocket in forum Dirt n' Dual-SportReplies: 14Last Post: 10-19-2010, 11:22 AM -
By stacyc72110 in forum Parts DeskReplies: 1Last Post: 04-09-2009, 06:44 AM
