Thread: CCW tha Heist
Results 561 to 570 of 1708
#561 Re: CCW tha Heist
06-25-2011, 01:08 AM
The main jet should not affect the low speed hesitation that you are experiencing..
Make sure that your accelerator pump is still working. It's easy to not get it right when replacing the float bowl. When you crank the throttle watch the accelerator pump and make sure it is going down.Vince
#562 Re: CCW tha Heistsome guy
- Apr 2011
- Peru, IL.
06-25-2011, 01:14 AM
How is the acclerator pump supposed to move? I just tried a google search and didn't find it for this carb. And how do I adjust it?
#563 Re: CCW tha Heistsome guy
- Apr 2011
- Peru, IL.
#564 Re: CCW tha Heist
06-25-2011, 01:29 AM
Does it pump when you twist the throttle?
I don't have a good closeup photo of my carb but should be one on the pdf below.
Tuning manual for a PZ26 carb ( PZ30 on the DF250RTB looks similar except for 30mm instead of 26mm size) is located at
http://walbro.com/brochurefiles/3368...g%20Manual.pdfVince
#565 Re: CCW tha Heistsome guy
- Apr 2011
- Peru, IL.
#566 Re: CCW tha Heistsome guy
- Apr 2011
- Peru, IL.
06-25-2011, 01:56 AM
http://www.hostingpics.net/viewer.ph...0_KEIHIN_3.jpg The pump should be on the left with the actuator hidden?
#567 Re: CCW tha Heist
#568 Re: CCW tha Heistsome guy
- Apr 2011
- Peru, IL.
#569 Re: CCW tha Heist
06-25-2011, 03:01 AM
You need to get the pump part under that black plastic part. You have to take the float bowl back off to get the pump under the black part.
Red dots point to the area that I am talking about. The black plastic part needs to push down on the brass part when you rotate the throttle. You have to take the float bowl back off to get the pump under the black part.Last edited by barnone; 06-25-2011 at 03:23 AM.
Vince
#570 Re: CCW tha Heist
06-25-2011, 03:29 AM
Gardo northern NJ/NYC
CCW tha Heist tha Widow
CCW tha Misfit (tha Wraith)
50 State legal and Worldwide
CCW Heist Riders
CCW
By MJH in forum StreetReplies: 259Last Post: 06-12-2016, 06:39 AM -
My day at PIT Motors LTD and the CCW Tha Heist
By Gardo in forum StreetReplies: 138Last Post: 05-12-2011, 06:08 AM
