  1. #1 Will a GN 250 fit a Pulse Adrenaline 125cc
    C-Moto Not-so-Noob
    Dec 2010
    Dublin
    Guys and Gals,
    I'm looking to find out what 250cc engine will fit as a replacement for the 125cc engine.
    Am I right in saying that this engine is a clone of the Suzuki GS125 or is it a clone of the Honda CG125. I don't really mind if I have to make some modifications around the Link pipe / End can. What would be the story with the engine mounts / ECU / Loom?
    Thanks for taking the time to read, any help would be greatly appreciated...
    P
  2. #2 Re: Will a GN 250 fit a Pulse Adrenaline 125cc
    Senior C-Moto Guru Kennon's Avatar
    Feb 2011
    Moscow
    hmm possible but you have to do some measurements of your own engine and get some from the GN 250 would have to modify or completely redo the mounts/engine brackets for example iit will need the appropriate amount of vibration reduction in the mounts/brackets being a bigger thumping engine, the ECu will have to be suited for the GN 250 some of the loom like ignition and lights will be fine to incorperate into a new one just make sure the connections are clean and wont be affected by the weather
  3. #3 Re: Will a GN 250 fit a Pulse Adrenaline 125cc
    Senior C-Moto Guru MJH's Avatar
    May 2010
    US
    You would need the engine and or the diagrams of the engines and the wiring diagrams would be helpful.
  4. #4 Re: Will a GN 250 fit a Pulse Adrenaline 125cc
    Dec 2008
    the chinese version http://motorcycle.sh.cn/viewthread.p...d=87720&page=1 frame: Suzuki GS125 that assembled by Hyosung in South Korea/ Donor machine : '92 GN250
  5. #5 Re: Will a GN 250 fit a Pulse Adrenaline 125cc
    MCM Chinese fellow td_ref's Avatar
    Jun 2010
    Shenzhen, Meizhou
    They are not identical. Pulse Adrenaline engine is similar to GS125, GN250 engine is bigger all around.
    I assume engine at your bike is also use as frame stress part. I would reconsider modify frame for this reason alone. Also there may be very little space for mounting carb.
  1. Pulse Adrenaline 125cc upgrade to 200cc?
    By sparky in forum Modifications (Cosmetic and Performance)
    Last Post: 08-31-2019, 07:49 PM
  2. My new exhaust on Pulse adrenaline
    By Thomas in forum Welcome to MCM!
    Last Post: 09-06-2011, 11:57 AM
  3. pulse adrenaline ignition
    By heeby in forum Maintenance
    Last Post: 03-03-2011, 11:48 PM
  4. Pulse Adrenaline
    By Rodders in forum Dirt n' Dual-Sport
    Last Post: 02-01-2011, 04:47 PM
  5. Nearly Done; Pulse Adrenaline
    By Sprocket in forum Dirt n' Dual-Sport
    Last Post: 10-19-2010, 11:22 AM
