Thread: Soberpete's YBR 250
Results 221 to 230 of 303
#221 Re: Soberpete's YBR 250
10-08-2011, 12:02 PM
Any factory painted exhaust should have been powder-coated. As I have heard quality issues with the YBR125 there is likely an issue with either the quality of the steel being used is questionable or the quality of the powder-coating. There are all sorts of ways of dealing with a rust problems.
http://www.halfords.com/webapp/wcs/s...5594_langId_-1
#222 Re: Soberpete's YBR 250C-Moto Guru
- Feb 2011
- Zibo, Shandong, China
10-08-2011, 12:39 PM
I may have already stated this in other words but I'd like to make another statement about it:
Most of the exhaust pipe is unweathered. It's only the front end, closest to the engine. It must be the heat from the engine that causes the problem (loss of the rust protective powder-coating?).
#223 Re: Soberpete's YBR 250
10-09-2011, 07:29 AM
Hey Pete, thanks a lot for the heads-up !
I came back yesterday after spending 10 days in Vietnam, man they're crazier than us over there, everyone powering through the streets of Ho Chi Minh or Hanoi with their cubs...
I went to my dealer today, finally saw my YBR 250, and went with their mechanic to do all the process to sell the Honda & transfer the plates to the Yamaha. It was rather easy I'd say thanks to the Honda mechanic, but it's a crazy process...
I'm leaving China tomorrow yet again, and everything should be ready (bike with plates, blue & green books) when I come back on Sunday Oct. 16th.
Only problem was that the bike was dropped at the shop before I came to see it, a good dent on the tank. The boss assured me he already ordered a new one to be fitted before I come back next Sunday. Needless to say, I thoroughly inspected the bike for other marks, but everything seem ok.
About the rust, I'll take extra precaution at this and try to keep it dry as much as possible. I never pressure-wash any vehicle, only sponge and water. It also allows you to check all your bike for problems or loose stuff.
So, if everything goes according to the plan, I should join you guys in the YBR 250 club next Sunday !
Fred
#224 Re: Soberpete's YBR 250
10-13-2011, 01:09 PM
The evil rust is starting to appear on my exhaust too... Needless to say I was told it's my fault as apparently word has spread that I ride to fast thus overheating it, (where did they get this strange idea??? BR
M ).
Anyway, this is clearly a poor quality paint they used on the exhaust, or something that is enough for 125 heat, but can't cope with the higher temperatures a 250 expel.
Solutions anyone? I read people suggest to clean with fine sandpaper, but what then?
I just installed a pair of Bosch horns bought on taobao, it's very easy and the supplier also sells the cable for the connection directly to the battery (sounds louder), it's very satisfying now to blast the occasional distract drivers. I strongly suggest this 130 Rmb upgrade, it's worth every penny and easy; the YBR is equipped already with the holes in the right place of the chassis to do this.
#225 Re: Soberpete's YBR 250C-Moto Guru
- Feb 2011
10-13-2011, 11:46 PM
After scrubbing the exhaust, we need to re-coat it with some high-quality, high-temperature resistant paint but I'm the last one who's gonna know where to get that.
Do you have any link for those BOSCH horns? I can't type much Chinese and Taobao doesn't get along too well with my English.
#226 Re: Soberpete's YBR 250
10-14-2011, 12:39 AM
I was reading around on the internet and apparently BBQ paint is a cheap way to protect those headers. Other high temperature paints don't work as well as they should. There is a professional ceramic painting technique, but can't be done at home, and the likely hood is that most companies in China will be as bad or worse than Jianshe Yamaha.
Krylon is the brand name to remember. I think one of your colleagues is visiting the USA and could bring you back some!
http://krylon.com/products/bbq_stove_paints/
#227 Re: Soberpete's YBR 250
10-14-2011, 01:06 AM
Sure thing, here is the link.
If you scroll down you can see also the cable for direct connection to the battery, which you will need and seems to be made for the YBR, you just need to connect the relay and the (-) pole where the original horn was mounted, the cable then just fit nicely on the left side under the plastic tank cover.
To fix the horns you will just need to purchase a couple of M6 stainless steel nuts to fix them into position. If you install it where I installed them you will not have any problem during hard braking, the horns can't touch the front fender.
Here is the picture of my installation:
#228 Re: Soberpete's YBR 250
10-14-2011, 01:11 AM
I know a place where they could get this paint job done, as for my work I sometimes need to apply teflon coating on some machine parts. This paint shop is specialized in teflon coating, I could take the exhaust apart and send there to apply teflon on it, what you guys think?
To my logic if it's good for cooking pans, it should be good for an exhaust as well! Surely the exhaust fumes can't be hotter than direct gas burn?
My guess for the cost of the operation would be around 100-150 quai.
As for this Krylon product it's most probably flammable, I think it's not possible to bring this even as checked baggage.
#229 Re: Soberpete's YBR 250
10-14-2011, 03:11 AM
check out this kind of products http://www.ofenmosmann.de/shops/heiz....php?cat=KAT37 (google translator is your friend)
It is typically used for hot waste gas pipes of fire places etc. I used it suitable for exhaust pipes on dirt bikes in the past. I am sure you will find similiar stuff.SWM RS500R, R1200GS LC
#230 Re: Soberpete's YBR 250
10-14-2011, 03:27 AM
Not sure if you can get these products but I use Rustoleum High Heat BBQ grill paint.Some others I know used stove polish.If you're burning off chrome then standard header paint will probably bake off pretty quick.I get about three years between coats,but I don't ride in harsh conditions.I have got caught out in the rain a few times.
in praise of the Yamaha YBR 250
By heiri in forum StreetReplies: 24Last Post: 08-05-2011, 05:30 AM -
YBR 125 rust problem after 460miles...never seen rain!
By palace15 in forum StreetReplies: 6Last Post: 06-12-2010, 02:36 PM -
YBR 125 bore kit
By Jmarc in forum Modifications (Cosmetic and Performance)Replies: 7Last Post: 03-18-2010, 05:58 PM
