Thread: JH600 stalling
Results 221 to 230 of 427
#221 Re: JH600 stalling
#222 Re: JH600 stalling
#223 Re: JH600 stalling
- Nov 2010
- Beijing
Kawasaki Versys 650
Shineray X2
#224 Re: JH600 stalling
#225 Re: JH600 stalling
#226 Re: JH600 stalling
11-23-2011, 01:22 PM
Originally Posted by fons
Actually mine has less problems because it is based on 40 year old Honda technology. It's when you get Chinese companies trying to do clever stuff like EFI and liquid cooling that you run into problems.
Although the next bike will probably be a Suzuki GW250.
Screw copycat, greedy, defensive, incompetent, abysmal customer service Chinese companies, never again. Nationalistic Chinese bikers hate these bikes too, and that says something! The government gives them the entire market, and yet they still can't get it right, except on all but the smallest capacity and most dated technology.
#227 Re: JH600 stalling
- Jul 2011
- Shanghai
11-24-2011, 08:45 AM
well, that's what i mean you shouldn't ride any made-in-china bike for your own safety issue.
if we all stop buying these bikes, then possibly they will change a little bit their mentality.
but actually chinese automobile manufacturer can easily catch up the latest tech by merge and acquisition. check out those latest actions. So hen you have fat cash on your hands, nothing is too far. Of course you have to play smartly.
#228 Re: JH600 stalling
11-24-2011, 10:22 AM
#229 Re: JH600 stalling
11-24-2011, 10:53 AM
Screw copycat, greedy, defensive, incompetent, abysmal customer service Chinese companies, never again. Nationalistic Chinese bikers hate these bikes too, and that says something! The government gives them the entire market, and yet they still can't get it right, except on all but the smallest capacity and most dated technology.同志仍需努力
#230 Re: JH600 stalling
11-24-2011, 12:55 PM
Well, if you allow me to go back to topic?
I follow this thread for 5 weeks now, and got more involved in the last 2 weeks.
From my experience with EFI, from what I have seen, from the observations and suggestions by others, plus a bit of actual measuring, I remain with my conclusion that the final cause of the stalls is a lean mixture. This was and is confirmed by measuring the exhaust of 2 bikes.
Of course the lean mixture is only at the end of the total process, and is caused by one or various reasons.
I still suspect that the mapping is set on the leans side to pass the regulations.
However, the ECU is only a part of the system, and in order to be sure that the ECU is the culprit, you must be sure that ALL OTHER equipment (sensors, connections, electric cables, power supply, etc) are fully functioning, calibrated as they need to be, clean and without any other problem.
What I see happening in the last week, is that not only the factory, but also some of you are loosing their patients.
I can understand that it all took too long, that the factory service is non existing, that that that.
But what I miss (and what I surely had done in the case I had a Jialing) is to go back to the basics first.
Clean everything, set every sensor, every switch, everything, according the manual factory settings.
This way, and only this way, you set a proper base, and allow the rest of the testing and trying to be successful.
Instead I see some people rushing from service shop to service shop.
I see service engineers without knowledge, without interest and without passion changing things, exchanging things, re-setting things, disconnection things.
The only result from all that is, that more and more is out of whack, and that any next "repair" is more a lucky shot then anything else.
We can not prevent the factory from acting erratic, but I think some of you might need to take a small step backwards, a deep breath and then just show some patients.
If I had a Jialing, I should have stripped it to the bottom already, just to be sure that the basics are correct.
I should then at least be confident that any further step by step approach was solely based upon the single item changed.
As said, only this way of working makes conclusions valid.
The above is not in any way meant offensive.
I can understand that I am perhaps lucky that I don't have a Jialing, and I can understand that some owners reached the limit. To each its own, no problem at that.
But I am perhaps also the person who can take a bit more distance by not having a bike, and by looking at it from a more technical point of view.
Guys, the winter is coming, give it 4 more months, take a deep breath, go back to the basics, and give it an other try.
I guess you all have learned more about EFI in the last 4 weeks then in your life time before .... imagine where we might be in an other 4 weeks ....
Well I will be in the tropics by then, but that is an other story haha ...
Eric
My new JH600
By Pfaelzer in forum Dirt n' Dual-SportReplies: 379Last Post: 06-07-2013, 08:01 AM -
JH600 impression
By Franki in forum Dirt n' Dual-SportReplies: 170Last Post: 12-05-2012, 04:51 AM -
Stalling high rpm qingqi 200gy
By dacru in forum MaintenanceReplies: 7Last Post: 04-13-2010, 05:44 PM -
My Cj 750 and JH600
By Zetazeroalpha in forum Welcome to MCM!Replies: 6Last Post: 05-13-2008, 10:57 AM -
JH600 and me
By Franki in forum Welcome to MCM!Replies: 4Last Post: 04-29-2008, 03:01 AM
