Thread: Cleveland Cyclewerks tha Misfit
Results 31 to 40 of 64
#31 Re: Cleveland Cyclewerks tha Misfit
12-19-2011, 04:43 AM
and another video found of the tha Misfit in the Wild
Gardo northern NJ/NYC
CCW tha Heist tha Widow
CCW tha Misfit (tha Wraith)
50 State legal and Worldwide
CCW Heist Riders
#32 Re: Cleveland Cyclewerks tha Misfit
12-19-2011, 04:52 AM
Here's Mr. tom Weaver of Weaver Rides taking a stock Heist for a spinGardo northern NJ/NYC
CCW Heist Riders
#33 Re: Cleveland Cyclewerks tha MisfitGardo northern NJ/NYC
CCW Heist Riders
#34 Re: Cleveland Cyclewerks tha Misfit
12-30-2011, 03:10 PM
"It's really just another resource for all the proud owners of our beloved 250cc CCW bikes."
Make that 229cc CCW bikes.
Vince
#35 Re: Cleveland Cyclewerks tha Misfit
12-30-2011, 05:44 PM
LIFAN ENGINES
Model:167FMM-M
Type: Single-cylinder,four-stroke,air-cooled
hand-clutched outer-balance shaft 250cc
Displacement: 227ml
Compression ratio: 9.2:1
Primary reduction: 3.333
Bore*Stroke: 67mm*64.5mm
Max.Power & Rotating Speed: 12.5kw/7000r/min
Max.Net Power & Rotating Speed: 11.5kw/7000r/min
Rated Power & Rotating Speed: 11.2kw/7000r/min
Max.Torpue & Rotating Speed: 16N.m/6000r/min
Min.Fuel Consumption:?354g/kw.h
Ldling Speed:1500r/min
Ignition:CDI
Starter: electric/kick starter
Lubrication: Pressure/splash
Transmission: 5speed
Model:167FMM
hand-clutched 250cc
Displacement: 227ml
Ignition:CDI
They stamp the blocks on all the engines, LIFANS have an (LF) prefix so they would be stamped with either LF167MM or LF167MM-M
I’ve ask for the engine codes on bikes people purchase and post about on this website and rarely if ever has anyone actually posted an image with the engine code.
#36 Re: Cleveland Cyclewerks tha Misfit
12-30-2011, 06:27 PM
It is safe to say that the frame is nearly identical to the original Honda, circa 1960. So that part of the design was likely a creation of a Japanese engineer at Honda, that has likely long since retired.
The Chinese make that frame in the million annually, the engines are all derived from the original push rod 125cc the mounting points to the frame are also likely identical across all the various versions of the engine. The Chinese added electronic ignitions and bigger cylinder heads.
There is nothing wrong with any of this, it is what it is, many people asked for a cool modern version of that bike and this version is about the best one so far.
But something about the claims of global engineering teams and such is actually not justified in the current offerings…the models are configurations of existing designs.
The originals were intended for transportation and still are, the CG125 are cheap in cost and sold all over the world, but mostly as a 125cc, these CG250 are just beefed up versions at least the engines are they offer a better top speed just enough for getting around town, just like the original but just with a bigger engine.
#37 Re: Cleveland Cyclewerks tha Misfit
12-30-2011, 06:41 PM
yes we are organizing and trying to help our fellow riders, and the Honda Rebel is a 233cc have you called Honda up and reminded them to change their stats
CCW doesnt hide the fact that is a 229cc engine but it is in the 250cc class like the DF250RTB. Its all about having fun and spreading the growing wealth of knowlege
have a great new years man, and Vince looking forward to reading about you adventures in 2012Gardo northern NJ/NYC
CCW Heist Riders
#38 Re: Cleveland Cyclewerks tha Misfit
12-30-2011, 08:45 PM
Gardo,
I asked CCW to change their specifications on their website for the Heist to 227cc and they banned me from their forum.
It's one thing to call a bike a DF250RTB or a Rebel 250 but the specifications should indicate the true displacement.
You need to change your web site so it reads 227cc instead of 250cc.
Heist Displacement 250cc from specs at http://www.pitmotorsltd.com/pitl1_013.htm
Same 250cc specs for the Misfit at same web site
Specifications for the Rebel 250 from Honda web site
http://powersports.honda.com/2012/rebel/specifications.aspx?CID=LG_MOTORCYCLE_STREET+REPRI SE+GOOGLE+LG_REBEL_SPECS+HONDA$REBEL$SPECIFICATION S
Specifications
ENGINE
Engine Type 234cc air-cooled parallel twin-cylinder Last edited by barnone; 12-30-2011 at 09:08 PM.
Vince
#39 Re: Cleveland Cyclewerks tha Misfit
#40 Re: Cleveland Cyclewerks tha Misfit
01-05-2012, 07:09 PM
Some aftermarket pipes from G&D
CCW Heist Riders
Cleveland Cyclewerks Mania
By Gardo in forum Modifications (Cosmetic and Performance)Replies: 0Last Post: 09-16-2011, 03:26 PM
