Thread: zongshen zs150-gy10
#1 zongshen zs150-gy10C-Moto Noob
- Mar 2012
- Guatemala
03-14-2012, 02:25 AM
I have been seacrhing this bike out here and have no luck with any reports/reviews on them. I am curious, because I have the chance to pick one up. It's a 2009 model left over in the dealership here in Guatemala. I like the way the bike is built, but I am concerned about actual performance. Also, I see that they use the GY-10 engine, but I can't find any other bike, zongshen or otherwise that uses it. How are these engines? what would be the japanese equivalent of it? The dealership was not successful competing with the other CB's.
Should I buy this bike? Can anyone point me to other threads on them?
Thanks for your help
#2 Re: zongshen zs150-gy10
03-14-2012, 07:02 AM
Uses water-cool pushrod (CG125 look alike) machine http://www.motorfans.com.cn/bbs/t_83767.htm
Showa shocks in domestic version
#3 Re: zongshen zs150-gy10C-Moto Noob
- Mar 2012
- Guatemala
03-14-2012, 12:39 PM
Thank you for the reply humanbeing. On to more questions. My son has a honda CG150 and nothing like the engine on the Zongshen. What parts do you consider "like" cg125? Would I be finding interchangable honda parts for the bike, like pistons, cams and other internal parts for it? Also I was able to find feedback from an owner that says that he had trouble with the transmission being very hard with the engine running, and that 5th gear was impossible to find, same as neutral. And that the amazing looking brakes siezed on him. I was inpressed by the build and size of the brakes as well as the showa bars, and 1 inch handle bar. But considering that the bike has been sitting in the showroom for three years, should I be concerned about all the rubber parts being brittle or cracked? The quality of the plastics seem 200% better than the other CB's. How is Zongshen's quality in that regard?
#4 Re: zongshen zs150-gy10
03-15-2012, 02:21 AM
Stay AWAY from anything that's NOT easy to obtain repair materials.
Honda CG150 in S. America is OHC. Chinese mod bore / stroke / cooling methond that based from CG125
That water-cool "CG150" is very common on chinese trike http://www.motorfans.com.cn/bbs/t_17128491.htm | http://item.taobao.com/item.htm?id=9226874621
There's a chinese doggerel: "買宗 (Zōng)申(Shēn) , 後悔終(Zhōng)生(Shēng)" -- Bought Zongshen , regrets lifelong
http://forum.jorsindo.com/thread-2330516-1-1.html
Copy & Paste texts to Google Translate will tells u horrible ZS story from 6# & 9#. Loncin are better. ZS eating oil (Rubbish ring + valve) & other parts are decent.
#5 Re: zongshen zs150-gy10C-Moto Not-so-Noob
- Sep 2008
- Cebu, Philip[pines
07-02-2012, 02:27 PM
The Zongshen engine used in the ZS125GY-10 / ZS150GY-10 and the ZS125GY-10C / ZS155GY-10C, was Zongshen's own design, like the Air-cooled engine in the Cyclone 'Pursuit' ZS125-50
I was doing a Google Search to try and find out what was the name of the Engine used in the ZS150 GY-10 and the 150/155cc version of the Cyclone 'Pursuit' ZS125-50 (which uses PZ125)
So I started with PZ150 and searched for that!
One of the Search Hits was this one:-
Chongqing Zongshen Power Machinery Co.,Ltd.
www.zse.cc/newsdetail.aspx?NewsID=1&CateID=18
13 New Products of Zongshen Motorcycle Engine Passed Appraisal ...
Commission, and the appraised models included YB110, PG/PZ150, W125, Z110 2-in-1.
So I did a search on www.zse.cc/ website for PG/PZ150
I only found the 125cc Watercooled engine ZS156MI(SB125), not the 155cc Version:-
The 125cc water-cooled engine in the CYCLONE 'Fly'
See http://factory.dhgate.com/motorcycle...p41392391.htmlType: ZS156MI
Another Name: SB125
Mode: Single Cylinder Four-stroke
water cooling Inclined(15°)
Maximum Power: 8.0kw/8500r/min
Maximum Torque: 9.2N.m/7500r/min
Compression Ratio: 10.5:1
Bore&Stroke: 56.5mm×49.5mm
Displacement: 124.04ml
Ignition: C.D.I
Lubrication: Pressure & Splash
Fuel Consumption: ≤367g/kw.h
Start: Kick & Electric
Clutch: Hand-operated, Wet-Multi-Chip
Gearshift Method: constant mesh/two stage transmission/5speed Gearshift
Net Weight: 30kg
Dimension: 358*350*446
• This engine has its own patents.
The patents numbers are ZL02307702.6 ZL02209337.0 ZL02203248.7 ZL01278341.2
• The cylinder head with rings water grooves and the unique combustion chamber reduce the noise effectively. This cooling system can get best cooling effect and reduce the thermal load of the key parts. In this way ,the life of the engine is lengthened and the performance of the engine is improved.
• Setting the oil channel outside can prevent the lubricant from being heated and get the best lubricating effect.
• Assistant electronically fan and sensitive temperature controller can make the cooling system radiate the heat automatically and keep the water stay in a best status.
#6 Re: zongshen zs150-gy10
07-02-2012, 03:03 PM
That image looks like a modified CG125, that gear case is as common in china as a dumpling.
Zongshen 250 gs
By aohelsuks in forum Bike Market - ClassifiedsReplies: 2Last Post: 03-30-2012, 12:38 PM -
HELP with zongshen atv
By kwhidby in forum MaintenanceReplies: 1Last Post: 02-07-2012, 01:02 AM -
Zongshen to buy Zongshen!?
By CrazyCarl in forum Industry News and Moto TalkReplies: 8Last Post: 01-28-2010, 03:16 AM -
AGB 30 - Zongshen
By txm123 in forum South/Central AmericaReplies: 4Last Post: 12-20-2009, 04:44 PM -
zongshen 200
By xs2 in forum Dirt n' Dual-SportReplies: 2Last Post: 12-15-2008, 03:42 PM
