Thread: spark plug?
  1. #1 spark plug?
    C-Moto Noob
    Mar 2011
    kennewick wa. usa
    i've got a Hibir QH 250 OGY according to my title... decals on bike says Ricardo db22... this bike is a cold starter.... can only use electric start as manual has a mean kick ... have to 1/3 throttle it at full choke and then keep it revved for about a minute... once it warms up it does fine.... i think i should be using a different plug ( meaning heat range, hotter or colder)... when i bought the bike from private party it had a new plug in it but don't know if it's the recommended plug or not.... can i just replace it with what the honda 250xl recommends.... if anyone can help me as far as plug numbers i sure would appreciate it... thanks so much for your replies
  2. #2 Re: spark plug?
    Dec 2008
    http://hondacg125.awardspace.com/spark_plug.htm
    NGK DPR8EA-9 IS the Honda spec that chinese engine based from.
    "Sourcecoil" often woes in older chinese bike, there's some CDI that "bypass" it (Uses DC ONLY )
    http://item.taobao.com/item.htm?id=1679629088
  3. #3 Re: spark plug?
    C-Moto Noob
    Mar 2011
    kennewick wa. usa
    thanks human being... i'll let you know if the plug you referenced makes a difference...
  4. #4 Re: spark plug?
    C-Moto Noob
    Mar 2011
    kennewick wa. usa
    that plug works great.... just choked and hit the button ( left the throttle down ) and it started right up... didn't have to rev to keep going... that's the one Human Being... thanks
  1. Metal-clad spark plug caps.
    By forchetto in forum Maintenance
    Last Post: 03-07-2012, 01:47 PM
  2. Spark plug heat range for CFMoto 250T-F?
    By joema in forum Maintenance
    Last Post: 11-23-2011, 03:13 AM
  3. official chinese spark plug standard
    By humanbeing in forum Maintenance
    Last Post: 08-06-2011, 05:13 PM
  4. spark plug - whats the difference?
    By jape in forum Maintenance
    Last Post: 04-13-2011, 12:43 PM
  5. spark plug gaps !
    By gy150 in forum Maintenance
    Last Post: 04-03-2010, 09:01 PM
