#1 Poor top end performance after big bore kitC-Moto Guru
06-04-2012, 09:38 PM
It's been a week since I installed my big bore kit and I am now having some engine problems; normal use is fine but under hard acceleration, speeds above 50mph or at WOT I get what I think are missfires and I cannot go above 55mph whereas I could do 65 - 70 with my 125 cylinder. I'm hoping that it's just because the piston rings aren't seated yet but I fear that it could be something more serious. I have upjetted the carb a bit but I couldn't feel much difference.
Can someone help me out please?Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#2 Re: Poor top end performance after big bore kit
06-05-2012, 02:09 AM
High rpm miss usually shows a rich mixture do a plug chop and see what the plug looks like
It should be light tan
any shade of black is rich
#3 Re: Poor top end performance after big bore kitC-Moto Guru
06-05-2012, 08:29 AM
I tried that but the spark plug was white so I upjetted it.
#4 Re: Poor top end performance after big bore kitC-Moto Guru
- Aug 2011
- texas
06-05-2012, 04:04 PM
check fuel filter and perhaps take a screw driver with ya next time you ride to tune your fuel mix screw (if have one) , be prepaired to stop often in is leaner out is richer , back it out 2 turns n go for a ride and tune 1/2 a turn at a time untill get no more performance increase then back it up 1/2 a turn
here is a quick test to see if she's lean , tape up your air filter leaving only 1/4 uncovered , go ride if it runs better she's lean and you need to mess with fuel mix / jetting (although your main 110 seems quite large enough so I asume just fuel mix is off )
you may also wanna peek at your valve adjustments again if backing out the mix screw (or taping up the air filter) doesnt show immediate benifits
#5 Re: Poor top end performance after big bore kitC-Moto Guru
06-05-2012, 04:15 PM
I forgot to update that, I now have a 115 main jet. I only have problems at high throttle positions and the air/fuel mixture screw only affects low throttle positions so I don't think that will make any difference, however I will try covering my air filter that's actually not a bad idea. I noticed that the o-ring on my carb where it connects to the cylinder head is a bit damaged and I could see a gap so maybe it was leaking which would explain the problem, I have put some RTV sealant on it to seal it up but I haven't tested it yet, I'll also check the valve clearences tomorrow once my engine has cooled. If it's still running badly I'll get a compression tester to see if I have a gasket leak or something.
#6 Re: Poor top end performance after big bore kitC-Moto Guru
06-07-2012, 09:12 AM
Ok I've got it sorted it! Luckily it was a bad seal at the carb. It's running fine now and the engine runs a lot cooler too.
#7 Re: Poor top end performance after big bore kitC-Moto Guru
- Aug 2011
- texas
06-07-2012, 09:59 PM
ya when I saw the post on leaking manifold I knew you had found your problem
just lucky u didnt hole something running THAT lean
#8 Re: Poor top end performance after big bore kitC-Moto Guru
06-07-2012, 10:27 PM
Performance Air Filter???
By xltomm in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 04-22-2012, 04:15 PM -
4 Curve Performance CDI Help
By Moonbloodsflow in forum Modifications (Cosmetic and Performance)Replies: 8Last Post: 06-28-2011, 04:48 PM -
YBR 125 bore kit
By Jmarc in forum Modifications (Cosmetic and Performance)Replies: 7Last Post: 03-18-2010, 05:58 PM -
Mechanical help needed - poor starting and running
By casper in forum MaintenanceReplies: 3Last Post: 01-07-2010, 04:00 PM -
Poor poor poor Culcune
By Snortin Norton in forum Off Topic DiscussionsReplies: 6Last Post: 07-05-2008, 12:03 PM
