Thread: Fuel leak from carb
Results 1 to 1 of 1
#1 Fuel leak from carbC-Moto Guru
06-23-2012, 03:27 PM
I noticed a fuel leak about an hour ago from my carb, it was comming from the overflow tube on the bottom. This happened right after I replaced the fuel hose, the new hose had a slightly smaller diamater than the last hose if that is of any significance. I put the old hose back on but it didn't make a difference so I took the bottom bit off the carb but I couldn't see any debris inside so I put it back together and the problem went away. What I want to know is why would a new fuel hose cause this? I've dissconnected the old hose plenty of times and this has never happened before.
Carb help!!!
By mark214 in forum MaintenanceReplies: 3Last Post: 06-13-2012, 09:49 AM -
oil leak Konker KSM 200
By bighead in forum StreetReplies: 0Last Post: 04-15-2012, 03:58 AM -
Carb woes - This should be an easy one! Please help.
By nimbus in forum MaintenanceReplies: 2Last Post: 04-11-2010, 01:45 AM -
Different Carb On QM200GY?
By firefightermatt in forum Modifications (Cosmetic and Performance)Replies: 6Last Post: 04-20-2009, 02:29 PM
