Thread: Adjust suspension
#1 Adjust suspension
06-30-2012, 12:27 AM
hi everyone, i have QingQi QM200-2D but here in Portugal is 125cc and not 200cc, and i like to adjust front and rear suspension, how can i do this?
The front and rear suspensions are very, but VERY soft.....
#2 Re: Adjust suspension
06-30-2012, 01:56 AM
you can stiffen up the front by putting a spacer on top of the spring
a piece of steel tube of suitable diameter will do the job
if its very soft now maybe start with a tube about 50mm long
the rear shock may have a threaded ring to adjust the preload
in which case just screw it up
if no adjuster then you can make a spacer
but you will need a lathe to make it
or go to a wrecker and try to find a stiffer spring
#3 Re: Adjust suspension
09-14-2012, 09:31 AM
Thanks for your answer, can anyone tell me what kind of oil i can put on front fork?
I really need to put some oil and on manuals don't say anything about front fork oil, and i don't know what kind of oil i most buy. Please it's urgent....
#4 Re: Adjust suspension
09-14-2012, 10:44 AM
Also check your rear shock and see if it has a place to add air. You will need a special pump to get the right pressure.
The oil you need is called "fork oil". Try 10 weight and if it still feels too soft go to 20 weight.
#5 Re: Adjust suspension
Micantech - New Suspension System
By Zorge in forum StreetReplies: 63Last Post: 05-10-2013, 05:17 AM -
Galaxy Suspension Setup
By richardktm in forum Dirt n' Dual-SportReplies: 0Last Post: 12-13-2010, 01:24 AM -
Qingqi 200GY-BA Motard Rear Suspension
By DeSaint in forum MaintenanceReplies: 14Last Post: 06-05-2009, 02:14 PM
