Thread: Shineray 重庆鑫源摩托车股份有限公司
Results 1 to 10 of 151
#1 Shineray 重庆鑫源摩托车股份有限公司
10-10-2012, 03:44 PM
Shineray/Xinyaun is China's 22nd largest producer of motorcycles, they manufactured 145,000 for the first six months of 2012, they gained 0.53% over the same period 2011, 71.78% of that total production was exported. 28,128 vehicles for the first half of the year went to the domestic market.
Their latest development is the X5 model...
x5-1 by mjhirz, on Flickr
The X5 has a single cylinder 400cc oil cooled engine (185YMQ)
400-185YMQ by mjhirz, on Flickr
Models commonly known as XR400 Model 185YMQ Type Single-cylinder, four-stroke, oil-cooled, lit, reverse Cylinder diameter 85 Piston stroke 70 Working volume 397.2 Nominal Displacement 400 Compression ratio 8 8 : 1 Starting way Electricity Ignition way CDI Ignition advance angle 6 ° to 10 ° (≤ 1500r/min ) of 30 ° ~~ 34 ° (≥ 4000r/min ) Gas distribution Top-mounted camshaft Lubrication method Pressure splashed Net mass 40 Dimensions 358 × 324 × 458 Maximum net power and speed 20/6500 Maximum torque and speed 30/5500 The lowest fuel consumption ≤ 354 Idling steady speed 1500 ± 150 Idling measurement of exhaust pollutants Co ≤ 4.5% , HC ≤ 1200 × 10 -6 ppm Starting performance ≤ 15 Clutch type Wet multi-plate Power output mode Chain Drive Transmission Type Gear constant mesh Primary speed ratio 2.666 Gear ratio i1 = 2.615, i2 = 1.789, i3 = 1.35, i4 = 1.12 Output sprocket number of teeth 15 Fuel type 93 Ⅱ Lubricant Brand SJ 10W-30 The LUB-OIL capacity 2.2L Spark plug model DPR8Z Lubricating oil pump type Inner and outer rotor type Magneto Type Permanent magnet DC Last edited by MJH; 07-10-2017 at 11:10 PM.
#2 Re: Shineray 重庆鑫源摩托车股份有限公司
10-10-2012, 04:10 PM
They also offer this model called an X2
250-X2 by mjhirz, on Flickr
170MM
170MM by mjhirz, on Flickr
Engine Model 170MM-A
Engine Type Single-cylinder balancer shaft of the 250 water-cooled dual cam Total cylinder volume (ml) 250 Bore X Stroke 70 × 65 Maximum power Kw / (r / min) 18Kw/8500 Maximum torque N · m / (r / min) 22/7500 Minimum fuel consumption (g / kW · h) ≤ 354 Starting way Electric start Transmission Chain Drive Brake mode (front / rear) Before the dish after dish Braking distance (m/20km) ≤ 7 Variable speed mode The six-speed constant mesh gear type Clutch way Wet multi-plate Length × width × height (mm) 2185 × 830 × 1260 Minimum turning radius (mm) Adjustable The biggest climbing the force (°) ≥ 40 Seat height (mm) 958 Minimum ground clearance (mm) 300 The maximum speed (kw / h) ≥ 100 Tire Size (front / rear) Front: 80/100-21 / rear: 110/100-18 Cover material PP Compression ratio 10.8:1 Carton size (mm) NW (kg) 128 GW (kg) Wheelbase (mm) 1500 Last edited by MJH; 07-10-2017 at 11:23 PM.
#3 Re: Shineray 重庆鑫源摩托车股份有限公司
10-10-2012, 04:21 PM
The XY250-5C
Roadwin-XY250-5C by mjhirz, on Flickr
Dimensions ( L x W x H ) ( mm ) 2010 × 740 × 1040 Wheelbase ( mm ) 1380 Curb weight ( kg ) 138 Maximum load ( kg ) 150 Maximum design speed ( km / h ) ≥ 110 Brake mode Front: Disc : Disc Brake operation Before: hand brake : foot brake Engine Type Single cylinder / oil-cooled / four stroke Engine Model 169YMM Displacement ( ml ) 232.6 Power ( kw ) 12.0kw/7500r/min Bore x stroke ( mm x mm) φ 69 × 62.2 Compression ratio 9.0 : 1 Torques ( N / r / min ) 18n.m/6000r/min Front-wheel models 110/70-17 Rear-wheel models 140/60-17
250-169FMM by mjhirz, on Flickr
Models commonly known as VJ250-1 Model 169FMM Type Single-cylinder, four-stroke, air-cooled Cylinder diameter 69 Piston stroke 62.2 Working volume 232.6 Nominal Displacement 250 Compression ratio 9 : 1 Starting way Electric / foot Ignition way CDI Ignition advance angle BTDC ended on 11 ± 2 ° (≤ 1500) of 33.5 ± 2° (≥ 4000) Gas distribution Overhead camshaft Lubrication method Pressure splashed Net mass 34 Dimensions 358 × 324 × 458 Maximum net power and speed 12/7500 Maximum torque and speed 18/6000 The lowest fuel consumption ≤ 354 Idling steady speed 1500 ± 150 Idling measurement of exhaust pollutants CO ≤ 3.8%, HC ≤ 800 ppm Starting performance ≤ 15s Clutch type Wet multi-plate Power output mode Chain Drive Transmission Type Gear constant mesh Primary speed ratio 3.333 Gear ratio i1 = 2.909, i2 = 1.867, i3 = 1.375, i4 = 1.150, i5 = 0.955 Output sprocket number of teeth 15 Fuel type 93II Lubricant Brand SG 10W-40 The LUB-OIL capacity 1.1L Carburetor Model PZ30 Spark plug model DR8EA Lubricating oil pump type Inner and outer rotor type Magneto Type Permanent magnet AC Last edited by MJH; 07-10-2017 at 11:25 PM.
#4 Re: Shineray 重庆鑫源摩托车股份有限公司
10-23-2012, 10:24 PM
I am not crazy for a 400cc single, but if I was to design a bike around that engine then….
First looks at a CB1300 Honda…
1300 by mjhirz, on Flickr
Then looks at this little mini CB130….
cb130 by mjhirz, on Flickr
A 400cc single of the Mini would be very cool…but bigger with 17" rims.
So would a water cooled 250...Last edited by MJH; 07-10-2017 at 11:29 PM.
#5 Re: Shineray 重庆鑫源摩托车股份有限公司
10-31-2012, 07:00 PM
Italian job on the swing arm "ROSSI MAMA" hard to explain !!!
#6 Re: Shineray 重庆鑫源摩托车股份有限公司
10-31-2012, 07:36 PM
Not Italian, Taiwan.
http://tw.page.bid.yahoo.com/tw/auct...?u=Y7155735266
one word Rossimama...no space, only sounds Italian.
#7 Re: Shineray 重庆鑫源摩托车股份有限公司
10-31-2012, 07:59 PM
I like the design elements, but it too small ,the big tires could be 17” like the types seen on a typical Motard.
A 223cc version and also a s 400cc version, that looks like that, but just bigger, about the size of a typical motard, I like the standard look and the custom parts, it just the little bike is just a mini, it is not impossible to make a standard with fatter tires and a bigger frame and use the 223cc and 400cc engines. Then that would be a line of model that would cover a bigger range of customers. I do not like the tail end though.
#8 Re: Shineray 重庆鑫源摩托车股份有限公司
11-03-2012, 01:01 AM
I like Shineray....they make this model which really is very appealing to me.
Only $1,100.00 USD in China, http://item.taobao.com/item.htm?id=14768483965
#9 Re: Shineray 重庆鑫源摩托车股份有限公司
11-03-2012, 01:23 AM
I also like the Richie rich version they have, but other seem not to like the bike?
http://motorcycle.sh.cn/t_17307786.htm
http://www.shineraymotor.com.cn/prod...sp?columnid=94
Fit and finish looks pretty good on those,
plus they are different.
#10 Re: Shineray 重庆鑫源摩托车股份有限公司
11-03-2012, 01:37 AM
They sell these in Argentina as a RX150 Sport for $1,800.00 USD.
I think the Chinese models look better...they also have the CVTT engine in the Chinese bikes.
CvTT by mjhirz, on FlickrLast edited by MJH; 07-10-2017 at 11:33 PM.
Loncin 重庆隆鑫机车有限公司
By MJH in forum Industry News and Moto TalkReplies: 177Last Post: 07-19-2017, 10:14 PM -
SENKE 鹤山国机南联摩托车工业有限公司
By MJH in forum Industry News and Moto TalkReplies: 72Last Post: 10-28-2016, 06:13 PM -
Nanfang 株洲南方摩托车有限公司
By MJH in forum Industry News and Moto TalkReplies: 11Last Post: 03-17-2013, 08:39 AM -
Wonjan 重庆望江摩托车制造有限公司
By MJH in forum Industry News and Moto TalkReplies: 11Last Post: 11-19-2012, 02:17 AM -
Dayang/Dayun 广州大运摩托车有限公司
By MJH in forum Industry News and Moto TalkReplies: 1Last Post: 10-04-2012, 09:23 PM
