Thread: Indicator Problem
#1 Indicator Problem
- Jan 2013
- Walton on the naze
01-29-2013, 04:19 PM
HI there i brought some LED indicators for my bike. Just recieved them in the post and have tried fitting them today. When all of them were installed i then tested them to see if they worked properly. As soon as i try to turn one side of the indicators on all of them come on. Plus when they are on i can not get them to flash they just stay static.
Can anyone please help because i have no idea why this is happening.
Thank You for looking.
#2 Re: Indicator Problem
- Down the road in China...
01-29-2013, 05:01 PM
you might have to swap the flasher relay (indicator relay) as well to work with the LED indicators.... hate bloody electrics....
#3 Re: Indicator Problem
- Jan 2013
01-29-2013, 11:45 PM
Thanks for replying to me mate. How do you change the flash relay if i might ask. I do not have an idea and the electrics on the bike are so fiddly it takes ages to sort something.
#4 Re: Indicator Problem
01-30-2013, 01:27 AM
LED lights need a resistor/controller. As i know they cant be connect directly to the power lines of standard light bulb turn signals. Or does indicators have these resistors built in?
Someone with good electrical understanding please correct if i am wrong.SWM RS500R, R1200GS LC
#5 Re: Indicator Problem
01-30-2013, 02:09 AM
Exactly as ShuBen has advised. Most often LED flashers need a resistor installed somewhere along the circuit (in-line resistor) to effectively modulate the current, else the LED act in various ways either flashing too fast (which is the most common complaint) or as you have found, don't flash at all. If you are not comfortable fitting a resistor then head to a automotive electrician, who would be able to fit exactly what you'd need and for not much money. If you try to do this yourself, then you will find that resistors have different ratings (ohms) and therefore would need to experiment a little to work out what you need. A way to overcome this problem is to find variable resistor (potentiometer) in combination with a dimming light switch (like what one can find inside buildings) rigged up to your bike. With this set-up fitted, once you get indicators flashing at the desired rate check the resistance across the circuit using a multimeter and "bingo" you have the nominal resistance for the desired flash rate.
Some LED indicators have resistors built in on the PCB within the indicator housing as ShuBen has advised, though based on your findings it is highly unlikely to be the case with the ones you have bought unless the resistors are the wrong rating for your bikes electrical system.Last edited by bikerdoc; 01-30-2013 at 03:21 AM.
#6 Re: Indicator Problem
01-30-2013, 03:23 AM
you might be able to find help or what you are looking for on www.superbrightleds.com
#7 Re: Indicator Problem
- Sofia, Bulgaria
110cc extra wires. gear indicator???
By arlie1180 in forum Parts DeskReplies: 6Last Post: 08-03-2015, 06:41 AM -
Problem with my qingqi 200 GY
By stefan.golinschi in forum MaintenanceReplies: 8Last Post: 04-08-2011, 10:46 PM -
Help Ive got a problem with my motard
By 123prestige in forum Modifications (Cosmetic and Performance)Replies: 9Last Post: 12-24-2010, 03:20 AM -
The Problem with Parts
By CrazyCarl in forum Parts DeskReplies: 1Last Post: 09-18-2010, 04:30 AM -
car problem ...help!
By jape in forum Off Topic DiscussionsReplies: 7Last Post: 05-26-2010, 12:56 PM
