Thread: kaiser ks 125-23 battery issue
#1 kaiser ks 125-23 battery issue
- Apr 2013
- plymouth,england
04-23-2013, 06:50 PM
high guys i have as above a kaiser 125 2007. bought it last year with a few bits needing attention electric start choke and a few other bits, BUT my main problem it the battery will not hold a charge, i replaced to the old one that was in there and the new one was spot on up until January, now before i go and buy another battery i wanna know if anyone else had the same issue and was able to resolve it? or do i buy another battery?
cheers guys rich
#2 Re: kaiser ks 125-23 battery issue
04-24-2013, 03:08 AM
Measure the whole wiring w/ Multimter (the cheapest digital model is enough to this job). Regulator/ rectifier is the main "suspect". Unregulated high volts F***ed the battery.
http://www.dansmc.com/MC_repaircourse.htm | http://www.sanxin.com.cn/info5/index.asp?id=6
The new one in fleabay: http://www.ebay.co.uk/itm/250843104432
http://item.taobao.com/item.htm?id=10186477231 | http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=53Last edited by humanbeing; 04-24-2013 at 02:00 PM.
#3 Re: kaiser ks 125-23 battery issue
04-26-2013, 03:22 PM
Check if you have a parasitic draw with a multimeter.
#4 Re: kaiser ks 125-23 battery issue
- Apr 2013
- plymouth,england
#5 Re: kaiser ks 125-23 battery issue
- Apr 2013
- plymouth,england
#6 Re: kaiser ks 125-23 battery issue
05-19-2013, 11:18 AM
A parasitic draw is something that drains the battery while the ignition is off, for example if the headlight some how stayed on that would cause a parasitic draw. You can test for a parasitic draw using the current measuring mode on a multimeter, you dissconnect the wire from the positive battery and connect them together with the 2 multimeter probes. It will tell you if any current is being drawed from the battery. There are lots of good guides on Youtube on this subject.
You can also check that your charging system is working by measuring the voltage at the battery with the engine running, I think 14.7v is the ideal voltage.Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#7 Re: kaiser ks 125-23 battery issue
- Apr 2013
- plymouth,england
05-28-2013, 09:39 PM
thanks for your help guess. i've resorted atm to disconnecting the battery when its parked lol, but its due for mot so i'll have it looked at
Throttle cable issue - Pulse Adrenaline.
By Sprocket in forum MaintenanceReplies: 6Last Post: 09-11-2018, 02:17 AM -
Carb Issue & help
By arancara in forum Modifications (Cosmetic and Performance)Replies: 6Last Post: 03-10-2013, 07:14 PM -
strange stalling at idle issue.
By palisadeguy in forum MaintenanceReplies: 8Last Post: 03-25-2012, 05:14 PM -
2009 Qlink XF200 Seat Mods / Bike Height - lowering issue
By JTC in forum Dirt n' Dual-SportReplies: 22Last Post: 12-08-2010, 02:02 PM
Scwarzcohenlaw Site
10-02-2025, 11:59 AM in Off Topic Discussions
