Results 1 to 2 of 2
  1. #1 Giantco Hunter 125 voltage issue
    C-Moto Noob
    May 2013
    lincoln
    After purchasing a 60 plate with 7k I seem to be having an issue with thevoltage on the bike, it uses the 156fmi lump.
    Despite changing the battery, the cdi unit, the rectifier and the stator I can't seem to get more than just under 12 volts meaning that with a bit of use the battery runs flat.
    Having changed all the parts above I'm a bit lost as to what to do next with it as I thought that changing these bits would have sorted the problem but alas no, so if anyone could give me a suggestion what to try next it would be hugely appreciated as I'm a bit stuck.
  2. #2 Re: Giantco Hunter 125 voltage issue
    Dec 2008
    http://www.mychinamoto.com/forums/showthread.php?5301 had similar story.
    Why changing CDI? It's powered by another AC source directly.
    You can't solve the ??? by just guessing (changing parts from here & there). What's the reading of wiring countinuty etc ... In extreme case the rotor may de-magnetize.
    http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=53 The reg works when "control (middle) to s/w (ON)" are connected!!! If something breaks btw them
    How to test reg: http://www.sanxin.com.cn/info5/index.asp?id=6
    Self-contain test system (By-passing ALL those time cousming wiring !!! ) http://www.motorfans.com.cn/bbs/t_125842_1.htm
  1. Giantco Hunter Sport Parts UK
    By LaPistola in forum Parts Desk
    Last Post: 12-03-2012, 12:56 AM
  2. RHINO HUNTER SPORT
    By GatorKev in forum Street
    Last Post: 09-22-2012, 01:33 AM
  3. Giantco City hunter 125 156fmi engine valve clearance
    By Chronicz in forum Dirt n' Dual-Sport
    Last Post: 03-28-2012, 11:15 AM
  4. Replies: 2
    Last Post: 03-08-2012, 05:44 PM
