Thread: Is this safe?
Results 1 to 10 of 14
#1 Is this safe?
- Jun 2009
- Jacksonville Florida
06-26-2009, 03:25 AM
Are these safe to use without worrying about melting wires and starting a fire. It says 35w and I thought the stock headlight was 55.... but wanted to run it by some people and double check, I have the qingqi 200
http://cgi.ebay.com/ebaymotors/H4-Bi...Q5fAccessories
06-26-2009, 01:13 PM
HID lights should be safe to use if installed properly. There is a question about their DOT legality but they should work fine on the bike and I know people who have installed them on their QingQi with great success.
The power consumption on an HID does not relate to it's light output like a halogen bulb. They are two different systems. You will get MUCH more light out of an HID with less power draw and the run cooler to so you should not have to worry about the reflector melting.
If you do install it, please let us know how it works.... and don't forget pics!
- Oct 2008
- Stafford, Texas USA
06-26-2009, 04:31 PM
The XF200 comes with a 35 watt headlight bulb, I changed mine to a normal H4 55 watt bulb and it works fine, plus alot more light.
Qlink XF200 Flat Black MODS: P&P Exhaust Pipe-125 Main Jet-35 Idle Jet-Jet Needle Clip On Forth From Top Position-Denso Iridium Spark Plug IX24-Sprocket Specialists #550-16 16T Front Sprocket-SAI Removed-Rear Fender Cut Off-Brake Light Flasher-55 Watt Headlight Bulb
- Jun 2009
06-26-2009, 06:52 PM
yea i was thinking about jsut getting the Sylvania silver star bulb but i want optimum lighting at night i was kinda worried about how these hook up
06-26-2009, 06:55 PM
If they're the same type...it will hook in just like stock. There's nothing different about the design of the Silver Stars besides their output. I use them in my Versys and they are a great improvement. Only downside is they are expensive and don't put out as much light as a HID.
- Jun 2009
06-26-2009, 07:58 PM
I have them in my car and compared to stock there is a large increase in output. But I would like more for my bike
- Jun 2009
06-28-2009, 10:24 PM
has anyone put an HID kit on their bike yet?
- May 2009
- Beijing
06-29-2009, 06:43 AM
I have been thinking about modding my headlights with HID as well. I have seen people add the HID lights on light bars, but not completely replacing stock lights.
My concerns are:
1. Heat
2. power consumption (little alternator in my bike, barely able to charge up the battery).
Would be great to see what others have done...2003 BMW F650 CS
2006 BMW F650 GS
1982 Kawasaki
Beijing <- New York <- Den Haag <- Paris <- Rotterdam <- Philadelphia <-London<- Minneapolis <- Mountain View <- Tysons Corner <- New York
- Jun 2009
06-29-2009, 09:50 PM
well the HID is supposed to be cooler and it consumes less power
- Jun 2009
Post-crash fork problem! Is it still safe?
By MotoDrunken in forum MaintenanceReplies: 6Last Post: 10-18-2008, 09:07 AM
