Results 21 to 30 of 114
#21 Re: Shineray X1 - mixed CG engine to bike?!
03-07-2016, 03:52 PM
No, Hall effect is different on Earth's southern hemisphere comparing to Hall effect on northern hemisphere, so maybe your bike is fitted with northern hemisphere pick-up.
One more detail that crossed my mind... Pick-up must to be some 0,3-0,5 mm (check correct value in some manual) from this... lump on a rotor.Ask me nothing - I DO NOT speak english. Really...
- fuck off
03-07-2016, 03:54 PM
How about a clear answer to my questions rather the cryptic clues :(
- fuck off
03-07-2016, 04:06 PM
This if I'm not wrong is the square type CDI?
And this is the round type CDI?
I think this is what my bike should be even if colour a if wire aren't the same but same connection points etc
Best test tomorrow to try figure out something for definite ! :(
#24 Re: Shineray X1 - mixed CG engine to bike?!
03-07-2016, 10:14 PM
This tells you were the wires go for a 6pin
http://i140.photobucket.com/albums/r...m.jpg~original
#25 Re: Shineray X1 - mixed CG engine to bike?!
03-07-2016, 10:24 PM
...how to test and correct values but did read 0.9ohms is ok on something...[/QUOTE]
AC-CDI
pink/yellow *** We don't care it (read the image above = to Reg/rec )***
Blue / white <-> green = pickup | seems OK but what's the voltage ?
What's the reading of AC-source[black/red] (ohm/ volt)?
Dc-cdi
- fuck off
03-07-2016, 10:54 PM
AC-CDI
Dc-cdi
[/QUOTE]
Hi
I can't make head or tails from the pictures - Black with red wasn't connected at all so can't test till it,
It's all a bit of a mess and I'm not clear yet what is what.
Only 4 wires from the stator where connected to the bike - NOT black with red tho
All wires are poorly connected and I really need to redo the complete connector with new terminals and get rid of the bad joins.
- fuck off
03-07-2016, 11:00 PM
Black with red has no connections to any other wire
It flashes 160ohms if you touch it to the metal casing only for a moment
#28 Re: Shineray X1 - mixed CG engine to bike?!
03-08-2016, 12:00 AM
That would go to the Rectifier/regulator to the battery in a DC set up. It only goes to the CDI for AC. The pic I linked to is for an AC type.
If you only have one wire connected to the two prong on the CDI it is a DC type.
- fuck off
#30 Re: Shineray X1 - mixed CG engine to bike?!
03-08-2016, 12:44 AM
No actually, that makes me think it is bad, you should check for continuity between phases and get nothing to ground.
Shineray XY250GY-2 MX Bike
By pinchers in forum Dirt n' Dual-SportReplies: 51Last Post: 10-01-2016, 09:08 AM -
Different engine choices in the CQR? Shineray vs. Zongshen vs. GTY vs. CBi500
By effertime in forum Dirt n' Dual-SportReplies: 11Last Post: 12-13-2013, 03:24 PM -
Shineray Quad Parts? (What kind of engine do they use?)
By quadman in forum ATV's/QuadsReplies: 1Last Post: 09-02-2010, 07:05 PM -
Swapping my Shineray GY7 200cc engine for a jiling 600cc
By life in forum Modifications (Cosmetic and Performance)Replies: 10Last Post: 06-17-2010, 03:38 PM -
Shineray GY-7 with 250cc engine
By Supersignet in forum Dirt n' Dual-SportReplies: 9Last Post: 05-03-2008, 02:41 AM
Scwarzcohenlaw Site
10-02-2025, 11:59 AM in Off Topic Discussions
