Thread: Shineray / XinYuan X5 review
Results 371 to 380 of 466
10-11-2016, 11:44 AM
I was quite satisfied with the Kenda tires. Just the wet grip is performing bit lower.
I used it for 10k km All terrain travel.
Only thick mud is closing the profile completely, but for that condition u need knobbis anyway
Sent from my HUAWEI P7-L07 using TapatalkSWM RS500R, R1200GS LC
#372 Re: Shineray / XinYuan X5 review
10-11-2016, 12:14 PM
For sure he needs because i think a picture tell a 1000 words ?
adobelightroom_27572613085_o_zpslgcie59x.jpg"Arguing on the Internet is like running in the Special Olympics, even if you win you're still retarded"
10-11-2016, 03:55 PM
Here is where u get with the Kenda
#374 Re: Shineray / XinYuan X5 review
- Apr 2011
- Taizhou, Zhejiang
10-12-2016, 01:05 AM
Nice pics Shuben and thanks for some info Prince
I do like to take bikes on bad roads and am simply doing some research before I buy. Ive found a lot of sets on taobao in sizes 2.75-21 and 4.10-18. I think now that those sizes might fit the X5. In the worst case I will buy the cheapest set (RMB120!!!) in that size and try them on, if fit then can buy better.
#375 Re: Shineray / XinYuan X5 review
10-12-2016, 01:16 AM
To convert mm size tyres into inches size tyres just ÷ by 25.4
So 90 -90-21 are 3.50" and the back 130 are 5.10""Arguing on the Internet is like running in the Special Olympics, even if you win you're still retarded"
#376 Re: Shineray / XinYuan X5 review
- Apr 2011
- Taizhou, Zhejiang
10-12-2016, 02:11 AM
As it was my guess at the beginning but a simple google search changed it all...hah Even the universal truths are not so universal after a google search hahah
look here according to this street and knobbies have different sizes. 130-80 streey are 5.00-5.10 like you said but 130-80 knobbies are 4.00-4.50. And the front in both cases (90-90) is 2.75-3.00 which has nothing to do with inches as it should be 3.50 like you mentioned ;)
Maxxis tire chart is also inconsistent 90-90 is 2.75-3.00 and 130-80 is 5.00-5.10
#377 Re: Shineray / XinYuan X5 review
- Aug 2016
- Ukraine
10-28-2016, 05:40 PM
Does anyone know something about ECU which is installed in X5? There is Synerject control unit http://www.synerject.com/en/2-3-whee...andalone-p30-6 I need to reset DTC (Diagnostic Trouble Code) and can't find any info how I can do that. I can't find info which diagnostic tool I can connect to the ECU to be able to clean the codes. I'll be thankfull for any help.
#378 Re: Shineray / XinYuan X5 review
#379 Re: Shineray / XinYuan X5 review
- Apr 2011
- Taizhou, Zhejiang
#380 Re: Shineray / XinYuan X5 review
- Aug 2016
- Ukraine
10-29-2016, 07:31 AM
I have a new motorcycle, Geon Grandtour 400. That's a copy of the X5 in Ukraine. After the third ride when I was almost at home (about 300 meters) I saw "check engine" light working. I waited a few minutes and finished the ride. At home I decrypted the light and found that it shows code "7" what means "Intake air temperature sensor diagnosis". I decided to disconnect/connect the sensor to be sure that the problem is not in the wires. After that I got one more code blinking by "check engine" light - "21" (MAP sensor diagnosis). That's because intake air temperature and preasure sensor are the same physical thing. So at the moment when I turn the key and right red button to start position I see that "check engine" is blinking "21" and then "7". Once I start engine the lamp goes to off state. I hope that it's blinking the errors from log and not the actual ones so I would like to reset them to see if they appear again. I'm contacting the dealer to know how he can help me. If no success with him I'll probably try to buy some diagnostic tool with K-line interface and will try to connect to the ECU.
Review of the Yamaha YBR 125
By Lao Jia Hou in forum StreetReplies: 23Last Post: 12-01-2013, 08:47 PM -
My Review of the CFMOTO 650NK
By Topmanda in forum StreetReplies: 89Last Post: 09-24-2013, 12:59 PM -
Galaxy XTR 250 review
By felix in forum Dirt n' Dual-SportReplies: 84Last Post: 09-14-2013, 05:35 PM -
DB200B / SHINERAY GY7 Canadian review
By kens in forum Dirt n' Dual-SportReplies: 22Last Post: 05-15-2012, 04:26 PM -
Galaxy XTR 250 Review
By Andy Hird in forum Dirt n' Dual-SportReplies: 40Last Post: 12-13-2010, 01:01 PM
