Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 69
  1. #41 Re: pulse adrenaline 150cc big bore kit fitted
    C-Moto Regular Biker1234's Avatar
    Aug 2013
    Uk
    Thanks for the reply much appreciated
  2. #42 Re: pulse adrenaline 150cc big bore kit fitted
    C-Moto Senior
    Jul 2013
    England
    Quote Originally Posted by offtheclockuk View Post
    hi guys, as you may have seen ive been pestering about the kit,
    i finally ordered one off ebay and with the help of my mate (who happens to be a very good part time bike mechanic) we fitted the kit today,
    the first thing i did was to paint the barrel black so that it didnt stand out so much when it was fitted.
    it only really took around 2 hours to go from rolling the bike in to rolling it back out again, everything went smoothly and there were no problems.
    i rode the bike home afterwards, i cant abuse it yet as it needs to run/bed in again but initial feelings are very good, there is much more torque than i was expecting,
    here are a couple of pictures from the build and a short video i took of it running, apologies for the sound quality, i do not have a proper camera only iphone4.
    http://youtu.be/ssJXEWU21ms
    james
    un painted by offtheclockuk, on Flickr
    starting to strip by offtheclockuk, on Flickr
    old small piston by offtheclockuk, on Flickr
    new big piston by offtheclockuk, on Flickr
    finished and ready to run by offtheclockuk, on Flickr
    link please
  3. #43 Re: pulse adrenaline 150cc big bore kit fitted
    Aug 2013
    Uk
    Sorry to bring this back up again ,I've now got my 150cc big bore kit and planning on installing it this weekend if I have time and was wondering if anyone can shed some light on this sai hole that you need to fill wondering where abouts it's located ? and will epoxy weld itself be enough to fill it ? I have included a pic of my own kit image.jpg is the hole you need to fill the one on near the top left hand side 2nd one down?
    RMR 150cc unique Supermoto with nice after market parts .Full DEP exhaust system,150cc big bore kit,Molkt 30mm carb with 115 main jet,Performance CDI & Ignition coil,Cone air filter,KOSO DB01+ Digital speedo with RPM Counter and lap time,Alarm + Remote start,Sound system,red breather hose kit,front and back mini carbon indicators,tinted headlight,Fat Bars
  4. #44 Re: pulse adrenaline 150cc big bore kit fitted
    Dec 2008
    You can tell which is the SAI hole from the picture.
  5. #45 Re: pulse adrenaline 150cc big bore kit fitted
    C-Moto Guru
    Jan 2012
    Norwich
    I didn't have to block mine off as the holes ligned up ok but if you got yours from eBay it might differ from mine a little. You could wait untill you have the cylinder head off and then see if the SAI passage is in the same place as before, it's the one close to the piston without a rod going through it.
    I did block mine off a while ago because the SAI valve was a bit dodgey but instead of filling the hole with epoxy I made a blanking plate out of a piece of scrap metal and I made a gasket using a sheet of gasket material. That way the hole can be unblocked if need be and there isn't any chance of a piece of epoxy comming loose and falling somwhere it shouldn't.
  6. #46 Re: pulse adrenaline 150cc big bore kit fitted
    C-Moto Regular
    Aug 2013
    wet wales
    Quote Originally Posted by Biker1234 View Post
    liquid metal
    http://www.ebay.co.uk/itm/LOCTITE-CH...item1e77851ba5
  7. #47 Re: pulse adrenaline 150cc big bore kit fitted
    Aug 2013
    Uk
    Thanks for the help guys really appreciate it
  8. #48 Re: pulse adrenaline 150cc big bore kit fitted
    Aug 2013
    Uk
    Hey guys can anyone give me some advice I'm more or less ready to install my big bore kit I'm off work the next few days booked time off work to do it but I'm worried about a few things,I have a decent torque rench and various adapters etc but can anyone link me to a torque rench or adaptor that will allow me to torque these bolts when I'm putting it back together ? I've attached a picture image.jpg I've highlighted the bolts in yellow ,the only thing I can get to fit in there is a spanner to loosen/tighten them because the engine fins come out a bit and prevent the wrench fitting in so any help on that would be great also if anyone could tell me the spacing for the piston rings or better still a picture as my Haynes manual doesn't cover the rings for some reason
  9. #49 Re: pulse adrenaline 150cc big bore kit fitted
    C-Moto Guru
    Jan 2012
    Norwich
    I had the same problem, I just used a spanner and it was fine. I forget which torque they require but if you tighten the 4 cylinder head nuts (20nm) or the cam cover bolts (10nm) you should get a good feel for what torque is required. Just don't go crazy tight and you will be fine.
  10. #50 Re: pulse adrenaline 150cc big bore kit fitted
    Aug 2013
    Uk
    Thanks Spencer,any advice about the piston rings wondering what the piston ring spacing should be if you happen to know ?also the order of the rings sorry to be a pain
  1. Pulse Adrenaline 150 big bore Kit
    By superfamous in forum Modifications (Cosmetic and Performance)
    Last Post: 08-04-2021, 08:24 AM
  2. Pulse adrenaline big bore help please
    By offtheclockuk in forum Modifications (Cosmetic and Performance)
    Last Post: 07-08-2014, 12:31 AM
  3. Pulse Adrenaline 125
    Last Post: 10-09-2012, 11:32 PM
  4. Pulse Adrenaline
    By jonesyboy in forum Welcome to MCM!
    Last Post: 10-15-2011, 05:59 PM
  5. Pulse Adrenaline
    By Rodders in forum Dirt n' Dual-Sport
    Last Post: 02-01-2011, 04:47 PM
Tags for this Thread
View Tag Cloud
