Thread: 150cc kit piston rings.
#1 150cc kit piston rings.
- Apr 2015
- United Kingdom
09-11-2015, 12:29 PM
Hi, just looking for some piston rings for an adrenaline 125 with the big bore kit. I found some on eBay for a cg150 engine which are for a 62mm piston and was wondering if they would work fine on a suzuki based gs125 engine as the big bore version has 62mm piston rings or does it not work like that....
#2 Re: 150cc kit piston rings.
09-11-2015, 02:36 PM
I don't think that you can simply bore out your bike's cylinder and fit suitable 62 mm piston - IMO, sleeve's wall to thin.
#3 Re: 150cc kit piston rings.
- Apr 2015
- United Kingdom
#4 Re: 150cc kit piston rings.
09-11-2015, 04:17 PM
A-ha, just rings!
Beats me.
I couldn't provide you reliable info, but if I would be in your shoes, I would find out (using Web or vernier/micrometer) what are the piston ring dimensions (not only diameter, of course) for both engines, yours and those on the CG clone. If they are the same, they will fit. If not... as Axl said, you "gotta have some patience". Simple as that.Ask me nothing - I DO NOT speak english. Really...
#5 Re: 150cc kit piston rings.
09-11-2015, 08:30 PM
http://www.dongya.cn/prodlist.asp?page=7&tp=4&keywords= CG150 62mm [1.2/1.2/2.5] is most common BUT there's other combnation. I would say MESAURE it 1st & ask the seller what's the spec of their rings...
HiGHER grade rings http://www.dongya.cn/prodlist.asp?page=2&tp=6&keywords=
Kinlon piston and ring set
By Rat man407 in forum Parts DeskReplies: 3Last Post: 09-30-2014, 02:04 PM -
how to replace piston rings pulse adrenaline?
By JordanRenton in forum MaintenanceReplies: 0Last Post: 11-22-2013, 11:26 PM -
cb 250 head, cam and piston upgrade?
By gusmanxtr in forum Modifications (Cosmetic and Performance)Replies: 0Last Post: 05-22-2013, 02:07 PM -
crf230 piston compression height
By gusmanxtr in forum Modifications (Cosmetic and Performance)Replies: 4Last Post: 04-24-2013, 11:35 PM -
150cc piston spec
By 50dude in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 05-19-2011, 12:55 AM
