Results 1 to 10 of 21
Threaded View
#1 QM200GY idle problem, valve clearances.Honorary C-Moto Guru
- Jun 2008
07-12-2008, 02:10 AM
Although very happy with my Qingqi-Qlink-Sinnis-Pulse adrenaline-Superbyke, etc QM200GY super motard so far,
I was never comfortable with the abscence of valve clearance check and/or adjustment in the makers handbook
maintenance schedule.
The Spanish importer tells me it's not required, EVER. Having ridden and
maintained bikes and cars for over 30 years I know this is pure bullsh*t, but
finally managed to get the settings out of him.
They told me 0.5 inlet and 0.8 exhaust. When I laughed at the ridiculously
large clearances for a Japanese-derived bike engine, the service manager went quiet,
consulted some papers and came up with the more reasonable 0.05 and 0.08. This, I reluctantly accepted.
As I am unable to locate a workshop manual for the Qingqi I bought one for its nearest equivalent,
the Suzuki DR200SE and learned there that Suzuki's clearances for both inlet and exhaust are 0.08 to 0.13 mm.
Thinking this was strange I searched through many forums, in several languages
and using the various names Qingqis are sold as in different countries.
I came across contributor "Catastrophyx" advice, backed by Qingqi Sweden,
concerning the problem with burned valves and advice to set them at inlet 0.10 and exhaust 0.15 mm.
Like all information that could be useful for future reference I copied the
messages to my desktop and forgot about it.
From 500 km onwards the bike started dying out ocassionally on stopping for
traffic lights, junctions, etc, and it re-started with some difficulty and in a
lazy sort of manner, being reluctant to rev up or respond properly to the
throttle. There was also a sort of low speed jerkiness. At speed, once under
way, it ran well and also from cold starts.
The idle speed was also badly affected by turning on the lights, making it
necessary to set the idle speed high with them off to avoid the idle becoming
too low with the lights on.
This is fairly normal on small engines with a low power output, but I thought
that a 200cc 4-stroke would have enough torque at idle to cope with an
electrical load of about 50 or 60 watts.
After wasting several days re-adjusting carburettor, cleaning and dismantling,
checking float chamber level, air leaks, ignition system, changing plugs,
testing breather hole in petrol cap, fuel flow from tank, etc, etc, I was about
to give up and just accept that I was beaten when I remembered my notes
about valve clearances. These I did not think to check at such an early mileage.
Before doing so I searched the Net to see if incorrect clearances could affect
things like the tickover and finding that it definitely could, I rushed to my
garage to check them out.
I found that they were at 0.04 and 0.06 respectively, probably adjusted to
the standard 0.05 and 0.08 in the factory, but due to initial valve seat settlement or recession,
they had closed up in 660 Km.
I decided to reset them to the figures according to the advice of the Swedish
Qingqi importer and forum contributor "CathastrophiX" (IN 0.10-EX 0.15mm).
I'm happy to say that this has cured all the troubles, the bike runs like a
sewing machine and the idle speed is now steady and totally reliable.
It also pulls much better from low revs.
I just hope that I caught it on time, avoiding a burned or damaged valve seat,
but for now hope that this advice is read by others with similar symptoms and acted upon without delay.Jincheng Monkey JC50Q-7
Skyteam Dax replica ST110-6
Zongshen ZS125-43
Qingqi QM110GY
| « Previous Thread | Next Thread » |
What matters more to you on an 18+...
12-25-2025, 07:20 PM in Welcome to MCM!
