Results 1 to 10 of 114
Threaded View
#1 Shineray X1 - mixed CG engine to bike?!Banned
- Nov 2011
- fuck off
03-05-2016, 10:33 AM
Ok I'm a bit confused but here goes
Bike is a Shineray X1 with rounded CDI one bolt coil original regulator. Was original CG150cc
Engine - now here's the strange bit, I think 125cc CG but runs like shit
So if the stator is from the square CDI system this could be an issue? Timing and or other mixing of AC or DC system?
This I don't know if both systems are the same as far as the stators goes.
What's what square and round CDI plugs?
Is each stator and pick up and flywheels the same? Or are they different?
I need to be sure I have the correct stator flywheel and pick up sensor to suit the bike before I can look at other things.
Also now I upgraded to a PZ27 carb and new upgraded air box too.
I got the bike free with issues
I got it running etc and working thru what I know was wrong.
So are there variations to stators pick up and flywheel affecting timing and or ignition? If yes what type do I need for the X1? If no then I can eliminate this as an issue.
I think it's a 125 so my carb is too big and will run like crap, best change the barrel to 200cc tune carb and ignition should all match?
Your knowledge greatly appreciated
| « Previous Thread | Next Thread » |
Shineray XY250GY-2 MX Bike
By pinchers in forum Dirt n' Dual-SportReplies: 51Last Post: 10-01-2016, 09:08 AM -
Different engine choices in the CQR? Shineray vs. Zongshen vs. GTY vs. CBi500
By effertime in forum Dirt n' Dual-SportReplies: 11Last Post: 12-13-2013, 03:24 PM -
Shineray Quad Parts? (What kind of engine do they use?)
By quadman in forum ATV's/QuadsReplies: 1Last Post: 09-02-2010, 07:05 PM -
Swapping my Shineray GY7 200cc engine for a jiling 600cc
By life in forum Modifications (Cosmetic and Performance)Replies: 10Last Post: 06-17-2010, 03:38 PM -
Shineray GY-7 with 250cc engine
By Supersignet in forum Dirt n' Dual-SportReplies: 9Last Post: 05-03-2008, 02:41 AM
What matters more to you on an 18+...
12-25-2025, 07:20 PM in Welcome to MCM!
