Results 1,181 to 1,190 of 6337
#1181 Re: Mini Tachometer
10-09-2011, 02:14 PM
Not much info on the tach. At about 7800 RPM the vibration gets real bad. Where I live in WNC is all curves and two lane which I love but there is no straight runs to get above 60 MPH. The mini tach is slow to respond so it's dicy to get accurate RPM numbers. I need to ride down to a straight four lane about an hour away to get some accurate numbers. Plus I left my GPS in Florida. I'll be back in flat FL in about a month or so and then I can get some accurate numbers.
The stock Chinese battery is junk. My second battery went bad so I am down until a new battery arrives so pulled the battery box off and cut the openings around the positive and negative much larger so access to the terminals will be easier.Vince
#1182 Re: Mini Tachometer
10-09-2011, 04:51 PM
Barnone,do you snow bird in FL?I know you guys get a good bit of snow at your place in WNC.
#1183 Re: Mini Tachometer
10-09-2011, 04:52 PM
F.Y.I. lithium iron battery: http://www.batterystuff.com/knowledg...article&id=185
2011 Yamaha Star 250
2010 DF 250 Bobber (sold)
2009 Triumph Bonneville T100
1993 Kawasaki Vulcan88(sold)
#1184 White Stuff
#1185 Battery Failures
10-09-2011, 06:05 PM
Vince
#1186 Re: Battery Failures
10-09-2011, 10:11 PM
That is a VERY good possibility. Vibration is the enemy of all lead acid batteries. Your new one will have enough padding to more than fill the battery box. You will marvel at how light it is and small.
I went with the 14ah as it is the same physical size. (I like over kill).2011 Yamaha Star 250
#1187 Re: Battery Failures
10-09-2011, 10:28 PM
Vince
#1188 Re: Battery Failures
10-09-2011, 11:23 PM
I put enough padding under the battery to build it up to stock height (so cables would reach as normal) and on top & sides,as no venting is necessary. The padding has peel and stick on one side, if you want to use it.
#1189 Re: Battery Failures
10-11-2011, 03:03 PM
mailman, did you ever get your DF regged in CT?
Gardo northern NJ/NYC
CCW tha Heist tha Widow
CCW tha Misfit (tha Wraith)
50 State legal and Worldwide
CCW Heist Riders
#1190 Re: Battery Failures
10-11-2011, 08:53 PM
DD350E-2 Bobber
Bobber Bikes
my 2nd 16 inch bobber
JH600B Information Wanted
