Results 1 to 10 of 14
#1 CFMoto 650TR smartphone/GPS holder install
10-04-2013, 02:12 AM
To begin, I needed to make some adjustments and modifications to the short OEM screen. These will be carried through to the tall screen when I eventually successfully obtain one through CFMoto.
Since I prefer a more direct line-of-sight view of my smartphone come GPS, I have where possible installed the same mounts on my various other rides with the exception of the Dragstar to which I fitted a simple PeriPower branded handle bar mount - simple.
RAM mounts to me have disadvantages which I don't like. Often these RAM mounts and holders are often put in locations where the device is prone or exposed to the elements. My method provides far more protection and I've been able to use and rely on the my smartphone/GPS in adverse weather conditions without having to rely on waterproof cases or removal of the device from the mount. Most RAM mounts are attached to mirror mounts or the top of brake reserviors etc. meaning a not so-line-of-sight view.
First remove the screen which was part of the modification to short OEM screen thread.
With screen removed (requires 4mm Allen headed 'key' spanner), proceed to remove two (2) PK screws near top side of dash fascia. Push in the four (4) inner circular plastic fasteners with a little force. Careful as only small amount of force is needed to move the mid section of the fastener in approx 3-4mm. Carefully use a small flat screwdriver placed under the underside of the outer fastener circumference and attempt to slowly wiggle the screw driver tip in a diagonal fashion so as the fastener lifts away from the dash fascia. Work ones way round the fastener, then attempt to remove fastener.
Once all fasteners and screws are removed. Using the flat tip of the screw driver, place the edge up under the top edge of overlap of the dash fascia and seperate carefully. Work along the edge from one side to the other. Once the top edge comes away, slide top dash fascia upwards this allows the three underlying locating flange pieces to clear the top edge of the headlight tupperware.
With top dash fascia tupperware removed, measure and approximate where hole needs to be drilled for the smartphone/GPS mounting arm.
Hole drilled just below top edge of underside of dash in center.
Close up view of hole, looks like drill bit slip, but this is just a reflection of the flash on the camera.Last edited by bikerdoc; 10-04-2013 at 05:08 AM.
#2 Re: CFMoto 650TR smartphone/GPS holder install
10-04-2013, 02:14 AM
I have been using a very generic and what was a widely available smartphone/GPS holder as shown in the photos below. Actually I only need the final 'bracket' and the actual universal device holder, so the other two 'brackets' including the 'suction cup' are superfulous to my needs. Given that the whole assembly can be had from various Taobao sellers for as little as cny10, the extra waste is of no consequence. I simply keep the un-needed parts in a plastic "parts" bin. I also bought 20 of the holders as spares. Also I plan on instally one holder on my Burgman 650 Executive on my next trip back home, since the same works well on my Burgman 650 Executive and Jetmax here in PRC. I have a slightly different PeriPower handlebar mount of my Dragstar 1100 Classic - no drilling required.
Bracket needed circled in red. The rest of the items are not required for this application. The bolt with the plastic head is just a little too short to work with the dash on the 650TR, so a slightly longer PK coach headed bolt was used.
Measuring the distance from the top of the dash for the hole on underside of the dash.
Bracket installed.
RHS view of bracket installation. Single small hole drilled.
Device holder in vertical position.Last edited by bikerdoc; 10-04-2013 at 05:42 AM.
#3 Re: CFMoto 650TR smartphone/GPS holder install
10-04-2013, 02:15 AM
Device holder in horizontal position.
RHS view of device holder with screen mounted.
Horizontal position of device holder used given height of screen relative to device (Samsung Galaxy Note 2 or more commonly HTC HD2). If the two bottom "feet" are placed in-line with the holder then it is possible to still fit a larger device using a combination of the side clamps (spring-loaded ratchet system) and as an additional safety precaution I use a double banded hair-tie. This also helps with taking some of the shock from vibration - should there be any.
Slightly off topic... note the darkened areas over the idiot lights on each end of the instrument panel. I applied a layer of automotive window tint film over these sections to compensate for the overly bright festoon bulbs installed by CFMoto in the dash. The neutral and high beam indication lights were the most bothersome while riding at night. Both these lights give off far too much glare IMO, hindering clear field of vision in dark surroundings. Light pollution! The window tint does a great job of toning this down without detracting from the functionality of the lights, or the aesthetics of the instrument panel. I ended up adding two extra small rectangle 30x20mm areas of film over the two warning lights in question with good results as a single layer of film was not enough. Had to do the same with the Jetmax instrument panel too.Last edited by bikerdoc; 10-06-2013 at 12:56 PM.
#4 Re: CFMoto 650TR smartphone/GPS holder install
- Jun 2016
- Wales
#5 Re: CFMoto 650TR smartphone/GPS holder install
06-20-2016, 02:49 AM
I've fitted the OEM tall screen. Did have an after market tall screen too but went with the OEM tall screen when it became available. Since then there's a whole range of different height screen's available in the mainland. I'm thinking about fitting a taller screen. But not certain as not riding the ICE bikes much these days.
#6 Re: CFMoto 650TR smartphone/GPS holder install
#7 Re: CFMoto 650TR smartphone/GPS holder install
#8 Re: CFMoto 650TR smartphone/GPS holder install
- Jun 2016
- Wales
06-30-2016, 08:14 AM
I have a taller screen as standard on mine compared to those fitted to earlier models, some versions of the TR were supplied with 2 screens, one small and one long, the parts listing for some years shows 2 screens.
Even though I have a longer screen it could do with being a bit longer still.
I cannot find any after market screens for the TR here in the UK, the TR is still a rare beast on the roads here.
#9 Re: CFMoto 650TR smartphone/GPS holder install
#10 Re: CFMoto 650TR smartphone/GPS holder install
- Jun 2016
- Wales
CFMoto 650TR muffler upgrade
By bikerdoc in forum Modifications (Cosmetic and Performance)Replies: 44Last Post: 05-30-2021, 08:10 PM -
CFMoto 650TR headlight access
By bikerdoc in forum MaintenanceReplies: 9Last Post: 03-14-2016, 05:16 AM -
CFMoto 650TR screen upgrade
By bikerdoc in forum Modifications (Cosmetic and Performance)Replies: 22Last Post: 06-06-2015, 11:54 AM -
CFMOTO 650TR NEW REVIEW
By prince666 in forum StreetReplies: 20Last Post: 05-31-2015, 10:49 AM -
CFMoto 650TR horn upgrade
By bikerdoc in forum Modifications (Cosmetic and Performance)Replies: 13Last Post: 12-16-2013, 12:37 AM
