Thread: Best oil to use in the UK
#1 Best oil to use in the UKC-Moto Noob
- Aug 2017
- West Midlands
08-22-2017, 07:33 PM
So my bike takes 10w 40 what is the best Motorbike oil to use
#2 Re: Best oil to use in the UK
08-22-2017, 07:39 PM
The most over discussed motorcycle forum topic ever. Did you even try to google it? Just get something made for a motorcycle that fits your price range and enjoy riding. If you live in the cold, go with thinner oil 5w30, if you live in hot, go with someting thicker 20w50. If you live in the middle, go with 10w40. There's a little book that comes with your motorcycle called the owners manual, it will tell you what is best for your engine.
#3 Re: Best oil to use in the UKC-Moto Not-so-Noob
- May 2017
- Wales
08-24-2017, 06:18 PM
When I had my Honda CBF125 in Wales, UK (2014-2017) I looked into this. Even my reputable dealer said ANY 10w40 is good for a 4-stroke, just as long as you change it regularly, as per the User manual. Even said its fine to buy Halfords or Lidl's own brands just as long as it's changed every 2500 miles :-)
Having ridden 2-strokes for years before I was kind of concerned. I have always used Silkolene and will continue to use branded i.e. Castrol, Rockoil or Idemitsu just for peace of mind.
My Qingqi owners guide says I should use 15w40 for my Sinnis Apache 250cc. All their 125cc machines are listed as 10w40 or 15w40 viscosity. All are based on air temperature of the country/area you live & ride in. My manual describes Fahrenheit, not Celsius so you'll need to convert. It says
15w40 - Range: -2F up to 104F+
10w40 - range: -4F up to 104F+
10w30 - range: -4F up to 86F
5w30 - range: -22F up to 86F
It also states that there are 4 (API classification) grades of oil, from high to low quality:-
SD - lowest
SE
SF
SG - highest grade/class
It says all Qingqi 125 & 250 4-stroke engines should use SE or SF level which seems to suggest mid range, not lowest or highest.
Also, to change every 3000km, which aligns with the 2500 miles recommended in the past for my Honda.
Hope this helps.
MarkLast edited by mark.evans101; 08-24-2017 at 08:45 PM.
#4 Re: Best oil to use in the UK
08-25-2017, 02:15 AM
Those words from Qingqi just the SAME
as outdated Jap manual they copied from . There's NO SD, SE, SF from regular oil seller
Play by the rule & buy those JASO T903 https://translate.googleusercontent....25E6%25A0%25BC certified MA/ MA2 bike oil if scares clutch slip
For those don't buy that hoax regular cheapie 15W40 is fine <...fine to buy Halfords or Lidl's own brands...>
https://motorcycleinfo.calsci.com/Oil.html | http://motorcycleinfo.calsci.com/Consumables.html#Oil is good article.
#5 Re: Best oil to use in the UKC-Moto Noob
- Sep 2017
- Cebu, Philippines
09-12-2017, 03:32 AM
you may use what is recommended in your owners manual...Change Oil Interval is more important...
